Old 08-09-2015, 12:53 PM
togaflyer togaflyer is offline
Default Boost pump
Deciding on a boost pump for the RV 10. The Andair has a simpler install since it does not reaquire a loop, it has a built in system. I did read there were issues with this pump back in 2011. Other pumps are Air Performance and the EFII.
Any info on the Andair or others is appreciated.
Old 08-09-2015, 03:13 PM
BillL BillL is offline
For what application? It is low on flow for the RV10.
http://www.vansairforce.com/communit...d.php?t=120250
Bill
RV-7
Lord Kelvin:
Old 08-09-2015, 03:33 PM
cdrandall92 cdrandall92 is offline
I would go with the EFII boost pump. In terms of service, reliability, and performance you can't do any better.
Chris
Old 08-09-2015, 04:26 PM
Jasonm Jasonm is offline
+1 for the EFII pump
Jason McKay
RV-10
Old 08-09-2015, 07:47 PM
The engine set up is for a Lycoming IO 540 with 9:1 jugs.
Old 08-10-2015, 07:33 AM
Don at Airflow Don at Airflow is offline
Default P/N 2090255
The aux pump we have been building for the last two years does not require the return loop. The connection on the pump is a simple in and out. Plus our pump P/N 2090255 is $390.00.
Don
