Old 08-09-2015, 03:30 AM
Sylvainsting's Avatar
Sylvainsting Sylvainsting is offline
Default Dynon ADAHRS alignment
Hello,
I created a little rack for my ADAHRS and riveted it, measuring carefully the pitch and roll. Now I would like to fasten the ADAHRS on it, but I don't know how to be sure it is lined up with the aircraft. Any suggestion for that ?
Thank you
Sylvain
RV7 QB (F-PSED), Tip Up, Aerosport IO-375, James Cowl, WW 200RV, Dynon Skyview, VP-X sport, Day VFR,
Flying...
Phase 2
Old 08-09-2015, 05:24 AM
Hornet2008 Hornet2008 is offline
I used a suitable spacer between the unit and the centreline rib. From memory it's within 1 degree.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 08-09-2015, 09:59 AM
climberrn's Avatar
climberrn climberrn is offline
Exclamation Idea
You could use one of those digital levels, and "zero" it to the level (or not) angle of the slider rails as called out in the plans. Then move that level to your ADHRS and see if it still reads zero. Repeat for other axis. Any correction can be made with a brass washer or two under the low side.
Joel
N626JA
RV-7A at CXP
Flying!
Old 08-09-2015, 11:03 AM
Default correction
Thank you for your reply but I was misinterpreted. See my drawing. Positions A and B are already made. I search the position C and I don't find any marker on the fuselage to line up the ADAHRS.
Flying...
Phase 2
Old 08-09-2015, 04:27 PM
MeAndMyToys MeAndMyToys is offline
Hornet answered in post 2. Parallel to the center rib.
N17BJ
RV-7 Tip Up slow build
200HP IO-360-A1B
Hartzell CS
Working on wiring and Fw Fwd
Got my RV-7 tail kit for X-mas 2012
Guess the Wife's on board!!
Dues paid 3/11/2019
Old 08-10-2015, 01:25 PM
ThanK you vers much for your replies . It is done
Flying...
Phase 2
