Old 07-12-2015, 07:24 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default A210 Issues
Low volume and/or weak RX signal on the ground? OK in the air.
"TX Inhibit" shown occasionally in primary frequency display area when trying to transmit. Smaller letters that the frequency display.
Also does anyone have a recommended set of settings that work well for an RV6 for the multitude of menu variables?
Jim Sharkey
Old 07-26-2015, 03:27 AM
pe2aab pe2aab is offline
Jim Sharkey
TX Inhibit will probably been showed due to a bad VSWR ratio.
Did you checked your antenna (SWR Meter)?
Is the connector of the antenna connected right?
I would first look into does things before you look further.
