Forming aluminum for a cooling outlet fairing
Gereed75 presented a fiberglass fairing that he made for the cooling air outlet that looks really good in a thread about exit drag. I would like to make one out of metal. It would have to conform to the radius of the cooling air outlet at the two corners. I can fill at the corners where the outlet turns out to blend in with the bottom of the cowl with fiberglass/resin/flox as necessary. One approach would be to make a wood forming block and beat it into shape. Another would be to fabricate it out of multiple pieces with no more than one bend on a part. And yet another way would be to build it out of fiberglass as Gary Reed did. Any good thoughts on how you would approach this?
Bob Axsom
Reason: Typos
