Old 01-02-2012, 08:01 PM
Doug94 Doug94 is offline
Default SJ Cowl Question
taking a moment to ask if others have had this concern with the SJ Cowl. On the left side of the cowling the cowl extends out from the fuse about 5/8", on the right side it lays perfectly - yes it is centered. If you have done a SJ Cowl on an 8 is this something I just need to strap down and install skybolts or is this a concern? Any input would be greatly appreciated. Thanks
http://s1018.photobucket.com/albums/...-21-42_391.jpg
Old 01-06-2012, 06:52 PM
Nick's Avatar
Nick Nick is offline
Total non issue. Strap it down, skybolt or hinges, youl be fine.
Nick "Rehab" Nafsinger
91TS Rosharon, TX
RV-4 Bought 2019, Day to Day Restoration while still flying. SDS EFI IO-360, Hartzell CS, DanH inspired custom intake, G3x Panel
RV-8 SB, "Back burner project."
RV-10 Built 2010, Sold 2019
Old 01-06-2012, 06:58 PM
vmirv8bldr's Avatar
vmirv8bldr vmirv8bldr is offline
Default Check clearance
Be sure to check your clearance on the left side before using hinges. Mine was actually in contact with Cyl #2 and I had to re-do it. All is well now and I have about 1/4" of clearance there,but it was a ton of extra work. I used the Dan Horton method and laid up the joggle instead of using hinges or the camloc mounting strip. I used nutplates on the horizontal interface to get the clearance. Hing eyes will eat about 1/16th. Do a search and you'll see my thread with pics, it was pretty recent, month or two ago.
Bart Filipiak
Eastvale, CA
RV-8 N74VB
Barrett IO-390
WW200RV
FLYING!!!!!!!
