Keep VAF
Going
10-18-2015, 07:29 PM
another paint booth
10-18-2015, 07:45 PM
Make sure you have good filters on the exhaust. I've had to buff my airplane out twice due to careless neighbors (one of whom had a booth).
Oh, and however many lights you have, buy more.
Finally, buy some scrap aluminum sheets and try your spray gear and materials out in your backyard. You can learn a lot without having to go all the way to the airport.
<This advice from a guy who taught himself to paint on his airplane's tail feathers. I learned a lot about sanding and buffing paint defects too.>
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
10-18-2015, 07:56 PM
yes, I'm concerned about over spray on neighbors. I'm pulling air thru these, doubled. Any experience?
and yes, I probably need more lights.
10-18-2015, 08:02 PM
I can't speak to those filters, but they are probably as good or better than what I used in my garage. I used 3 box fans in parallel, with a cheap air filter taped to the upstream side of each fan. My cars were parked 50' from the exhausts and I never had overspray problems.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
10-19-2015, 04:48 AM
Exhaust filtration
The filters will get coated with paint very quickly and require replacement. Consider cheap glass filters and cover them with disposable non woven fabric. A little tape will old the disposable fabric in place til fan suction nails it to the filters.
My experience says you don't need a "wind tunnel". Go easy on the fan.
Larry DeCamp
RV-4 fastback in process w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
10-19-2015, 05:18 AM
thanks for that comment. I was concerned about air change rate. with the exhaust filter in place, the fan should change the air once per minute for a booth this size. will that be enough? I may need to experiment with the filters.
12-27-2015, 07:19 AM
Intake
Did you end up providing an air intake? I had to keep the plastic from getting sucked in around the plane and getting weird airflow.
12-27-2015, 09:29 PM
no, I did not have an air inlet fan. I wrapped the plastic around completely and overlapped on the floor. I needed to put something on the floor or it would rise. I used a 2x4 but a thin floorboard over the entire floor would be better. I have a 7 ft. wide booth. 8 ft wide would have been better. then use 4 x 8, 1/4 inch floorboard.
12-27-2015, 09:45 PM
12-27-2015, 10:05 PM
this was the end of the second coat
end of third coat, no significant difference
Thread Tools |
Display Modes |
Hybrid Mode
