VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   ADS-B for RV-12 (https://vansairforce.net/community/showthread.php?t=98790)
edward7048 04-19-2013 05:57 PM
ADS-B for RV-12
I recieved an E-MAIL from Van's that they haved shiped my RV-12
kit for dynon's ads-b.
MacPara 04-22-2013 09:00 AM
When you receive it, could you let us know if the instructions touch on the retrofit issue?
RFSchaller 04-22-2013 03:18 PM
Has anybody heard of a D180 retrofit plan from Vans to add ADS-B? There have to be enough D180 RVs out there to make it worthwhile.
Bill_H 04-22-2013 08:28 PM
The Dynon ADSB Receiver only works with the Skyview system, not the D180. You can retrofit Skyview to replace D180 with parts from Vans. That is in fact the basis of the original RV12 Skyview system.
I bought the ADSB receiver and cable and antenna from Stein Air and will be installing it in a couple of weeks. I'll post on that. Like others, as a retrofit I am mounting the ADSB Box to the back side of the baggage bulkhead and avoiding running new antenna cable and wires over-under-around the brake pedal bar and through the system block tunnel.
RFSchaller 04-22-2013 10:13 PM
Maybe somebody at OSH will have a good option for those of us with D180s. Pulling out my D180 and spending another 4 or 5 grand to put in SV is not viable for me.
Bill_H 04-22-2013 10:36 PM
IPAD mini, Foreflight, Stratus.
The big deal with ADSB is the subscription-free weather, tfrs, etc. on the moving map, right? The D180 has no map. Or did you have something else in mind that you wanted depicted on the D180? Traffic?
Brantel 04-23-2013 06:02 AM
Rich,
I am afraid that the D180 most likely will never integrate with anything ADS-B related. It has no MAP and Dynon has said for many years that it is limited by hardware limitations so major future changes like adding a MAP are not possible.
edward7048 04-26-2013 04:38 PM
I recieved the ADS-B kit for my RV-12 today. The drawings are very
good for installing it into a completed aircraft.
RFSchaller 04-26-2013 05:28 PM
Brantley,
I agree the ADS-B In function will probably never be available to D180 RV-12 owners. I just keep hoping we aren't forgotten in the transition to ADS- Out. It seems like once Vans went to Skyview there hasn't been much thought given to those who spent the money on what was then the standard package D-180.
My Dual XGPS170 and WingX Pro have proved to be a satisfactory VFR option.
Rich
RFSchaller 04-26-2013 05:30 PM
Brantel, sorry I mangled your name in my last post! Believe it or not it was spell check that did it.
Rich
