GNS430 vs. GNS480
Based on advertized capability I was ready to go with the GNS480 but a friend with a GNS430 said the Garmin originated 430 is much more intuitive to use that the Apollo originated 480. What is your experience?
Bob Axsom |
You can download PC simulators for both models from the Garmin site and check them out yourself. The links are in the upper right corner for each product:
http://www.garmin.com/products/gns480/ http://www.garmin.com/products/gns430/ The user guides are also online. It'll take an hour or so to learn and check them out, but it's a big $$ purchase. It's worth spending the time. After I did that exercise, I found the 430 easier to use. However, I believe the 480 has some higher level flight management capabilities. I'm sure somebody can elaborate further on that. |
Bob,
Check this link and explore Tom Roger's Avionics West web site. He has insightful articles that may answer you questions. http://www.avionicswest.com/myviewpo...alive.htm#1115 I hope to see you again at next year's Cup Race. Robert Saltsman, Race 19 |
Thanks Guys
Good information from the Forum as usual.
Robert, if they can pull it together agan for 2007 (it always seems to be a struggle) it will be fun to fly the cup race again. You have to be very proud of your performance in that bunch of tough but good competitors. Bob Axsom Race #71 |
480 fan but...
I've always really liked the 480 (even before it was Garmin :D). It also gives you WAAS right now (though 430/530 WAAS support seems right there).
As for easier vs. harder. I really think it is what you get used to. For example, I really like the way a KLN94 will delete a duplicate waypoint when you insert a STAR on the fly and it always throws me for a loop when I switch back to 430/530 and it doesn't. On the other hand, I like the way Garmin handles holds... My one concern about buying a new 480 is its status as a purchased, mature, product dwarfed by an expanding family. If you know a 430, you can work a 530, all the nav features on a G1000, etc. With that in mind, I wouldn't look for much in the way of new features or anything beyond minor maintanence firmware support. Good Luck! -jjf |
Once the "W" series Garmins come out, do we really think the 480 has much life left in it? I guess there are a few little features that it does, like displaying an HSI on it's screen, but with the advent of EFIS systems, especially when/if they support TSO-146 (will require a WAAS GPS and TSO-146a support), I wonder if the 480 won't be relegated to "maintainence mode" and all the focus put on the "W" series.
Truth be known that already has happened. The only "feature" that I know of for the 480, since it's TSO-146a certification, was really a bug fix. Remember, it can't support all the WAAS GPS approaches without more memory and the appropriate code changes. Makes one wonder what Garmin really bought UPS AT for? |
IFR or VFR?
The 480 also has the SL30's NAV/COMM section, meaning that it can monitor the standby frequency, track two VORs, etc. 430 is much cheaper than 480, but I no idea what the street price will be for the 430 with WAAS. |
The 480 does understand Victor airways, which can be nice for entering a clearance (as opposed to looking at the chart and finding the waypoints at each bend). It is really nice hooked to an MX-20 in IFR chart mode.
But I don't think it is a huge factor for IFR. In busy space like SoCal, I typically just enter the first few fixes and the final destination anyway since the clearance frequently changes. Then, once I am on my way, I fill in the rest of the clearance a bit at a time (don't forget to fly first! ;) ) -jjf |
| All times are GMT -6. The time now is 09:19 PM. |
