VAF Forums
-   -   Double Battery Design Ideas (https://vansairforce.net/community/showthread.php?t=98564)
rleffler 04-15-2013 08:49 AM
I'm very similiar to David, with a pair of 680s. I modeled mine after Bill Watson. Both of us have Kitlog sites if you want to look up the details.
The only unusual part of my installation is that I'm using a VP/X Pro with dual batteries and dual alternators. Vertical Power recommends dual batteries or dual alternators. Some may think it's overkill, but I think I'm covering all my bases.
It's pretty easy to modify the battery tray to accomodate the additional space for the second 680. It's only a few inches larger than the tray provided in the kit.
bob
MauleDriver 04-27-2013 03:49 PM
Here's how I did it for (2) 680s.
http://www.mykitlog.com/users/displa...g=43554&row=26
Fred.Stucklen 04-27-2013 05:34 PM
Aux Avionics Battery
II have a PC680 main battery, and a 7.5AH aux battery for powering ALL the avionics during engine start. The two batteries (both lead acid) are tied together during normal operations So both are equally charged - no diode drops), but automatically separate (via an under-voltage sense circuit driving a contactor) if the main bus voltage goes below 12 VDC, and during the time the engine starter is being engaged. Both batteries are used separately to power the essential avionics. I ALWAYS turn ALL avionics on prior to engine start, and none reset during engine start. I have manual switch operation of both battery contactors as well (OFF,AUTO, ON).. Both batteries are above the rudder pedals inside the cockpit, accessible via inspection covers on the front deck. If anyone is interested in the circuit design, I can post a PDF file of the schematic....
Originally Posted by lammers4699 (Post 762188)
Is there anybody that considered to install a second battery (only for avionics and EFII system) up front? I have a second generator taking the place of my vacuum pump location. If os, where, how large and what electrical installation was used?
MauleDriver 05-16-2013 04:36 AM
That sounds just about ideal.
