Tank/Leading edge joint mismatch
So I just fit the tank to the main spar for the first time, and everything lines up perfectly, except for at the very tip of the leading edge, the radius of the tank vs the outboard LE don't quite match, as pictured. The rest of the joint at the splice strip is perfect, only the very tip is disjointed by about a skin's width.
I am thinking this will tighten up once all is riveted, or worst case scenario the joint could be smoothed with filler before paint, but did anybody else have the same experience? ![]() Thanks in advance as always Chris |
I had the same , it did tighten up some after riveting, I beveled and tapped the protruding skin slightly, then used pro seal to fill the gap all the way around the tank..
Greg. |
It will tighten Chris. Move on...
Had similar
| All times are GMT -6. The time now is 02:32 PM. |
