Fuse on the Way!
Woohoo! Placed my order for the SB fuselage today and just had to tell someone. :D Don't forget to beat the Vans price increase that happens on Monday...
Congratulations!!
Now is the time to get the shop in order, and any needed supplies ordered.
Doh!
Doh! No QB! At least it looks like you might have a -3 to fly in the meantime... If I could get back there I'd split it with you:cool:.... Anyway, maybe I'll lend a hand in a deburring, dimpling or riveting session sometime.
Congratulations. Soon you'll have a shell you can sit in and make funny airplane noises!
I found the fuselage being one of the more satisfying kits to build. You are doing something different everyday and you can see progress daily too.
Enjoy it while you can. The next kit is where all the infamous fun begins.:D Bob |
Congrats Mike!
If anything, I think I'd have rather quick built the wings, which are basically bigger versions of what you already did in the tail feathers... with lots of wash, rinse, repeat. |
Fuse orders
I also ordered the kit before the increase. Hope it's here before June .
Fell off the fence to the "left" I guess...
I was definitely on the fence for a while about going QB on the fuse, but I just figured I'd rather spend the money on other things in the future, like avionics or paint, or therapy....:D |
When I saw your original post, I went to your kitlog to see where exactly you were in the build, but it hadn't been updated in a while...I see that it is now. I'm at about the same point in the project, flaps ready to skin and match drill, one aileron trailing edge to rivet, the other is waiting for replacement parts, to correct a goof-up of a correction of a goof-up. Don't ask...fuse kit is supposed to ship end of April. Sounds like there might be a multiple -10 coming out party near the same time (left unspecified).
I used the gun for the proseal, but mixed it and filled my own tubes. Ended up going through three quarts of the stuff - I don't know how many prepared tubes that would equate to, as mine weren't always full, and I didn't always use every last drop. Ended up ordering a fourth quart for trailing edges and anything else that might come up. ==dave== |
It sounds like I'm actually quite a bit behind you. I haven't even started my ailerons or flaps, and I'm not ready to close up the wings either. I wonder, can you build and install the flaps and ailerons without closing up the bottom skins in the wings?? Anyhoo, I ordered my fuse kit to beat the price increase. I'll probably have it sitting for a little while before I finish the wings and can tear into it, but at least I won't have to wait for delivery when the time comes. Plus I save a few bucks besides... |
Thanks.
Mine will likely ship towards the end of May, so I have a little more time. However, I still need to do a few of the things you mentioned, as well as finish my tanks. Steady as she goes...
Like Joe, my plan is to match drill and dimple the bottom skins, feather the edges, then cleco in place for now til all the internals are complete. I haven't actually attached the tanks yet, either. And, it looks like one of the ailerons has a little warp to it - will need to decide if it will be used as is and rebuilt later if necessary or if it's significant enough to redo now. I figure I've got five weeks minimum til the fuse shows up, should be enough time to get everything assembled...
==dave== |
| All times are GMT -6. The time now is 02:04 AM. |
