VAF Forums
-   -   Opening tanks to avoid potential leaks? (https://vansairforce.net/community/showthread.php?t=97883)
rjcthree 03-26-2013 05:49 PM
My tanks were built with the gasket, not prosealed. I am considering opening them up and looking into them (QB) and only sealing with proseal. Based on other builder comments, it seems like a fine plan. Any gotchas(besides prep, etc?)
Rick 90432
pierre smith 03-27-2013 04:53 AM
Mornin' Rick...I'm old school..."If it ain't broke, don't fix it"
Unless they're leaking, I'd leave them alone because they may leak afterwards.
Best,
robertahegy 03-27-2013 07:06 AM
I agree!!!!
Roberta
Walt 03-27-2013 07:14 AM
I would never install a set of QB tanks without opening them up for inspection first. Rather than buy new gaskets, I would use PS to close them up. Make sure you use plently of PS on the screw threads, this is where many of the cover plate leaks originate.
Brantel 03-27-2013 07:16 AM
Tons of folks have found that the nuts were never tightened on their vent lines with QB tanks. If you have access, I would check em...
6 Gun 03-27-2013 07:37 AM
Tanks
On my older quick build i had to open to install gauges and i went back with Aviation #3 on cork seals and screws the reason is on my past Rv6 we had a tank leak and tried to fix it without taking the tank off and i sure would not have wanted to try that with PS on the cover in the 2" to work in .
Bob
Mel 03-27-2013 08:02 AM
I've seen many, many tanks with gaskets leak after several years.
The cork gets saturated after a while.
I would remove the covers, thoroughly inspect inside, and reinstall with pro-seal.
rjcthree 03-27-2013 08:54 AM
I should have been clearer . . .
For me the time to open the tanks is now. They are happliy match drilled for incedence, and are are back in the rack, so I can get to them with little trouble.
On further thought, the loose nut question scares me a bit, so I'll be opening them up and nutting the fittings inside, then sealing without gaskets, I think.
Rick
GLPalinkas 03-27-2013 09:43 AM
I think Pierre and Roberta missed the fact that you aren't flying yet. If you we're flying I would agree with them. (It was early morning for them lol)
However, you can easily get a look inside now before the wing install. I used ps and no gasket. Just my opinion but I have seen fewer leaks with this method. Also, I used square head screw fasteners instead of AN screws "just in case".
Example may not be the exact screw. I don't remember and I'm out of town.
http://www.mcfeelys.com/product/RMS-1404
KleensRV6 03-27-2013 10:27 AM
Best,
Ain't you got enough work to do:eek: Listen to Pierre, no drips, no worries, no reason to make additional work unless you have a real love for working with proseal.
KleensRV6 03-27-2013 10:43 AM
Best,
edbooth 03-28-2013 09:09 AM
I understand the wings are not installed yet. Take it from a 4 time builder, checkem' while you can. I have had two quick build leakers. Also, even with no leaks showing up now, it's not a 100% guarantee they won't show up later.
agough277 03-28-2013 12:10 PM
pressure test first. if it aint broke......
