VAF Forums
-   RV Ongoing Maintenance Issues (https://vansairforce.net/community/forumdisplay.php?f=76)
-   -   Innertube Choices/Prices (https://vansairforce.net/community/showthread.php?t=9753)
Kyle Boatright 08-03-2006 06:56 PM
I need to replace the right tire on the RV-6. The one that gets flat spots because I drag the brake on takeoff. Also, I'd like to have a new tire and tube "on the shelf".
Anyway, I was going to order a pair of tires (Air Hawks - I've gotten good service out of this set) and a pair of new tubes (Michelin Air Stops - these really cut down on how many times you need to air-up the tires.).
The tires are about $42 ea from Desser, but the tubes are $50 each. Aargh. Somehow it really bothers me to pay more for the tube than the tire. In my world, a tube should be $5 and shouldn't leak.
Any thoughts other than simply biting the bullet and springing for a new pair of Air Stops?
dan 08-03-2006 07:14 PM
http://www.rvproject.com/pricewatch.html
No good news on the tube front (the AirStop tubes are worth every penny, though). But might give you a cheaper source for the AirHawk tires.
Hope this helps. Please report any cheaper prices to me by email.
Ironflight 08-03-2006 07:45 PM
Kyle -
If it helps any, even the cheap tubes aren't cheap - by comparison, the Air Stops are a hundred times beter for only a few dollars more....my kit came with the cheaper air stops (not Michelin), and I had to add air every couple of weeks. The Michelins I replaced them with go months!
Paul
