Which fuel injection
Planning to make my final engine choice shortly and start placing orders this Summer for an IO540 and accessories. Currently looking at the 6 cyl PMag for ignition(it is being introduced at Sun-N-Fun), but still wondering what to do for fuel injection. Currently looking at airflow performance and efii. More complicated to setup the efii, is it worth it? Will there be a significant difference in fuel efficiency between the airflow performance mechanical injection system and the efii electronic injection system?
EFII
I have no experience with efii, but went with AFP because that is what Allen Barrett recommended for my IO540. It has been rock solid over 3 years.
Jim Berry RV-10 |
Every experimental engine builder I talked to recommended AFP so, I have AFP
FI
Mine is ECI and I couldn't be happier. The electronic fuel injection and ignition system sound very interesting though.
AFP!
2 airplanes and AFP is what I have and could not be happier.
If (when) I build a third, it is going to be AFP again. Don Rivera is a frequent contributor in this forum and a very knowledgeable man. |
P Mag deliveries
P Mag has promised to start delivering the 6 cylinder model for at least 5 years now at each of the airshows they are at. Don't believe any delivery dates that they quote to you.
Gary Specketer |
+1 for Don at Airflow...great guy.
Best, |
EFII systems for O-540
Hi Bill,
We make dual high energy electronic ignitions for the O-540 in both single and dual ECU versions. We also make a complete electronic engine management system including electronic fuel injection and dual high energy electronic ignition for your engine. The full system is also available in both single and dual ECU versions. In addition, our system is modular. If you choose to start out with just our ignition, you would have the option of adding the additional components for the fuel injection in the future. If you have any additional questions, please contact me at: robert@protekperformance.com Best of luck with the project, Robert Paisley |
FI
I also have Robert Paisley's totally redundant dual electronic ignition. It has it's own separate battery in case the main buss fails. It is a great system, uses automotive Iridium plugs, starts quickly and allows me to lean the fuel flow about one gph less than I could before. I am very pleased with and highly recommend his electronic ignition. I can't comment on his fuel injection system as I haven't seen or flown with one yet. |
| All times are GMT -6. The time now is 04:38 AM. |
