Leading edge left and right
Left and right leading edge splice strip. Aft most nut plate aft most rivit shop head is rubbing on spar flange. It's not siting flush. This is happening on top and bottom. It appears I need a one leg nutplate here. Any thoughts? Have checked the plans and plan on calling van's this afternoon.
If you want good advice, please provide a photo and/or plans page and task #.
I noticed this as well on mine. Please report back with Van's reply.
Thanks |
Thanks Justin. Can't call vans until 3:30 eastern but will let you know. Feel better another builder is experiencing same issue.
try from pc
picture of issue
I can't tell how off it is but I would just squeeze that rivet connecting the nut plate a little more.
I believe this issue was discussed at some point in the past and the fix was to squeeze the rivet a little harder to flatten it more.
Vans reply
Squeeze rivit to gain clearance or replace with one leg nutplate.
I squeezed mine and it did the trick.
Thanks to all. My main concern is that over time ,with tank installed, any clearance will be eliminated and a rubbing situation will possibly cause a structural problem on the spar. Maybe over thinking!
I noticed the same thing on my wings.
I just (over) squeezed that rivet a bit, and got a bit of breathing room. |
It looked to me like the space between the spar flange and the step bar was sufficient to 'hold' a shop head, so I didn't worry about it. Looked like part of the design...
![]() ==dave== tanks finished, waiting to test ordering fuse |
This has been discussed in the past - well-known issue. Over-squeeze the rivet to get the clearance. I really don't think you want the rivet rubbing against the spar.......
| All times are GMT -6. The time now is 02:03 AM. |
