Best fire ext mount for RV-7?
I searched for previous threads and did not come up with good pics. Would like to see recommendations to mount 1.3# small halon extonguisher in an accessible spot on a 6/7.
thanks.... |
I mounted mine between the seats vertically. You just have to be careful not to interfere with the flap actuator.
Halon in the cabin? just wondering,
I have a map box on the lower R side of my panel and mounted the extinguisher to the bottom of the map box (above the passenger's knees). Don't have a photo.
Greg |
Right under your knees on the fwd spar fuel line cover. I used a doubler to stiffen it up.
bonehead composites makes this, it is excellent and I have it:
http://www.boneheadcomposites.com/m8...rmrest%20.html ![]() |
Horizontal between the seats
Have mine in between the seats horizontally, fits tight but is accessible and out of the way in normal circumstances. Bracket is mounted to the small cover over the elevator linkage.
Heres where mine lives.
FWIW Bob, I originally had mine between the seats as well, but it really didnt like sitting in direct sunlight. I found it u/s at first annual :eek: Hasnt dropped any weight in 2 more annuals since I moved it - and i do check it regularly now. First thing the supplier said was"no direct sunlight". I figured it was easier to move it than remember to move it every time you leave the plane outside. I believe that the metal valved extinguishers are far more reliable, but it was hard enough finding anyone to sell me one at all let alone exactly what I wanted. Access obviously great for PIC, requires 2IC to loosen shoulder harness slightly. Cheers ![]() |
right side forward of the spar
[IMG]
[/IMG] |
Anyone tried on top of the fuelpump-cover?
That's where I'm considering. Any good reasons not to use that position? |
Placing it on the front of the spar wasn't an option for me because I have a 7A and the gear leg mount doesn't leave enough room for an extinguisher in that location. Richards' point about not leaving the extinguisher in direct sunlight is a valid comment but I'm hopeful my Kroger sunshade will do the trick when I don't have the canopy cover on. :) |
The 1lb 3oz halon hand held is right between and behind the seats in my RV6 . It has since been raised about 6 inches since this pic was taken .
http://www.flickr.com/photos/lylehef...n/photostream/ If I put my right arm over the seat back It's right there. |
I mounted mine on the fuel pump cover.
However, I wanted to make a different point about the actual fire extenguisher itself. You can see the black plastic top to mine (via the image link), vs the metal top in Daryls image. GET THE METAL TOP. My plastic one pops off if I so much as LOOK at it sideways. :mad: The neck support in the bracket actually causes it to come off too. Annoying and obviously not good for quick use in emergency. POS :mad: |
For those who want something other than Halon, here is an aqueous foam, non-toxic, and non-corrosive fire extinguisher. It is available with a mounting bracket too!
Each type has advantages and disadvantages. The good: Halon requires no clean up. Foam is cheap, can be sprayed on your body parts if needed, stays in place longer, and is arguably more effective. The bad: Halon can suffocate you and is expensive. Foam can freeze at low temps. YMMV! |
| All times are GMT -6. The time now is 04:16 PM. |
