VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   ADSB in Canada (https://vansairforce.net/community/showthread.php?t=96658)
h&jeuropa 02-19-2013 05:35 PM
ADSB in Canada
I live in Michigan but sometimes fly to Canada. I understand that we will be legal with UAT In and Out in the US after 2020. Does anyone know if US planes will be able to fly in Canadian airspace with just UAT In and OUt or will US planes have to have Mode S Squiter?
Jim Butcher
dynonsupport 02-19-2013 07:01 PM
Canada has no ADS-B mandate, so you don't need ADS-B in any format up there at all. They also have no Mode-S mandate, so Mode-C is fine. However, since you DO need ADS-B out in the USA by 2020, it's generally cheaper to buy a Mode-S transponder for ADS-B Out than it is to buy a UAT AND a Mode-C transponder.
From http://www.tc.gc.ca/eng/civilaviatio...-menu-5859.htm
Transponder Requirements
The U.S. Government requires aircraft to be equipped with a Mode A and Mode C transponder to cross the U.S. border in either direction (inbound or outbound). If you do not have a transponder, you must contact the U.S. Transportation Security Agency (TSA) for a waiver.
Aircraft are to be equipped with a Mode C transponder when operating in Canadian Class A, B, C, D and E airspace, as specified in the DAH (TP 1820E), which is available from NAV CANADA (CAR 601.03).
RV-4 02-20-2013 05:28 PM
Canada
''Canada has no ADS-B mandate, so you don't need ADS-B in any format up there at all. They also have no Mode-S mandate,''
Yepp We know.....unfortunately.....:o:rolleyes:
Bruno
Snowflake 02-20-2013 06:10 PM
Unfortunately? I can live without regs requiring *more* expensive hardware in my panel, thanks...
