Finalizing Panel: All thoughts welcome
Hi all,
I am in the final throws of sending my panel of to be CNC'd and engraved for my RV-10. I am after any and all comments as to the layout to ensure I have missed no specific issues and I have covered all bases. Link to pdf : http://dl.dropbox.com/u/95034127/Panel_Design%20V2.pdf UPDATED!!:http://dl.dropbox.com/u/95034127/Ful...2020120130.pdf - Noted changes: Switches more aligned, panel space for annunciator lights, all positions checked and re-checked. Dial alignment confirmed (Could'nt centralise due to panel supports, trying to maintain standard rear supports). Push to talk still being investigated.... Updated: https://dl.dropbox.com/u/95034127/Fu...2020120202.pdf Changes: Looking at where I can utilise a remote transponder and how the panel may work with that. Yes there is a new remote transponder that will work with AFS... it's sort of a Trig... Made modifications in line with many comments from this thread. Thanks guys. Room top left for annunciators. Some technical changes where AFS does not require GPS source change. Note, can't centralise "dials" due to support bracketing. Want to keep rear sections standard. I have chosen to use some colour coding so that the dash is simplified under stress, and elected to use toggle switches so that they can be easily replaced should it be required. I have also created some separation on switches to try and segregate the functional requirements. The colour coding is as follows: Green (NOW Grey): All good to Go; normal operating position Yellow: Alternative operating due to failure/problem White: Standard operating alternative The instrumentation I am looking at completing in the cutouts is as follows: --- Primary Instruments --- 2 x AFS 5500 with dual magnetometers, and a single GPS 1 x VPX-Pro (hidden) 1 x AFS Autopilot (flat pack) 1 x PAR100EX - Radio/Audio Panel (Backup radio) 1 x Garmin GTN650 1 x Trig 22 ADSB-out compliant transponder Dual Alternators (hidden) --- Backup Instruments --- 1 x 2.25" UMA Airspeed Indicator (thanks Bob...mistype) 1 x 2.25" Winter Altimeter 1 x 2.25" ADI2 with backup battery 1 x Standard whisky compass (on windscreen mount - not shown) I have also wired a complete bypass electrical solution for a complete VPX-Pro failure. (mid top of panel) Of course this is highly unlikely to happen. I plan to have this in black anodised aluminium as a replacement for the standard Vans panel. Please feel free to make any comments, or raise concerns. And another update: https://dl.dropbox.com/u/95034127/2012_02_05_Font_B.pdf Modified the font to see if this provides an easier readability. Spaced the writing a little further from the switches. Needed to add back the transponder due to certification requirements of ADS-B altitude encoding for 2020. Unfortunately due to space and screw holes, needs to be central. Am happy with that as the primary instruments for backup, Airspeed, AH, Altimeter and Compass all in same position. Modified colurs so that they have more contrast. Final Panel: https://dl.dropbox.com/u/95034127/20130210_Final.pdf I have now completed the panel and it is being submitted to Front Panels Express. They have been GREAT!!!! Extremely happy with thier service. The configuration has changed somewhat, I am now incorporating the Dynon Transponder unit instead of the Trig-22, and have added some additional content. I want to thank everyone for helping me get to here. The information and discussion has been INVALUABLE. If anyone wants a copy of the panel file OR wants any of the macro objects I created for the purpose. Just drop me an email. I would be glad to help. Thanks in advance. |
My only comment is, why two altimeters? An airspeed indicator would be beneficial.
If the budget permits, you may want to consider getting one of the smaller monitor screens for the right side. I put one in to entertain the person in the right seat. But it appears that AFS is no longer selling them. Too bad, that was an inexpensive way to display EFIS data. Bob |
Double, tripple, quadruple check your spacing.
I finished the layout of my new panel and was thrilled with how well it was all going to work. When I installed my switches and breakers I realized I had miscalculated the spacing and they were a tiny bit too close. I had to scrap the panel. I finished laying out the second new panel and was thrilled with how well it was all going to work. I test fit everything. I then painted and labeled everything. When I went to reinstall the switches, I realized the keyed ring on the switches was larger than I had allowed for and they slightly covered some of the labeling. It was not enough to force me to disassemble and re-paint/label but it was a bit of a bummer. |
Altimeter/Airspeed indicator
Thanks Bob,
Ah, yep. Mistyping. It was a UMA Airspeed Indicator.... When you say AFS is not seloing the smaller monitors.. which ones are you refering to? the 3500 series? Quote:
Aftermarket panel.
Andrew, this is a good opportunity to use a much nicer panel than the flat aluminum sheet Van provides. There are several that really beautify the interior. Here is one:
http://aerosportproducts.com/ I have a modified, three-panel, Lancair panel in mine: ![]() Best, |
Yes, the 3400, 3500, & 4500. AFS used to offer screens in a variety of functions. One was just a video monitor that slaved off a functional EFIS. So it appears to the user as a fully functional EFIS, but it reality it was just a screen driven by another EFIS. The benefits was to be able to add an additional screen at a much lessor cost. |
Andrew I like the layout. It is very similar to what I have. Attached is my
Aerosport Standard panel with the AFS 5500 screens. I love the layout Geoff |
Looks like your transponder is in the best place for the round airspeed indicator. And if you have an angle of attack instrument, that might go in that location or to its immediate left.
I'm thinking that the upper left section of the panel is the easiest to scan on take-off or approach and landing. Dave |
Andrew,
Overall I like your layout. I've recently done my panel, some of the design concepts being similar to yours. I have a few thoughts to offer. Due to time constraints this afternoon, I'll limit my comments to broad issues. As has already been mentioned, you gave the transponder better real estate than it deserves. The transponder doesn't need to be part of your instrument scan. I suggest you swap positions, putting the three backup instruments to the left, closer to the center of the pilot's field of view, and put the transponder to the right of them. Also, consider mounting the transponder in a standard 2.25" round hole configuration, rather than the non-standard smaller cut-out. Using a standard round hole will give you more flexibility for future upgrades. It will also probably be more aesthetically pleasing next to the three other round holes. Speaking of the round holes, check your screw hole patterns. It looks like the lower left hole on the rightmost instrument hole is out of position. And the center instrument hole doesn't have screw holes... I'm not reviewing it to that level of detail, just something I noticed. Is this meant to be your dimensioned CAD drawing that will get built, or is this just an initial sketch? Along the same lines as the transponder location, the area above the left EFIS is also prime real-estate, and would be an ideal place for annunciators if you had them. Or otherwise, maybe the A/P if it fits? Anyway, taking up that space with the switches and pots that you have there seems like a waste. Those could go anywhere, certainly don't need to be in the pilot's center of vision. About the engraved legends, I suggest you have a small test card made to try out different font types, font sizes, font spacing, all caps versus lower case, engraving thickness, and infill colors. You can't judge these well by looking at a drawing. You need to see it for real, in the actual process and materials used, at a realistic distance and range of viewing angles, and under different lighting conditions. I suspect that as you currently have it, it might not be as easy to read as you would want, especially under low light. About the use of legend colors in general (aside from contrast issues in low light), I think the concept has some merit, but is better to use more judiciously. The objective should be to make it easier to scan the panel and quickly and reliably attain the info you need, whether it's to verify that everything is set in the "normal" condition, or to quickly find a switch that you need to actuate, etc. As you have it currently, it looks to me a little too busy, where the jumble of colors makes scanning the switches more confusing, not less. Personally, I would stay with white for most if not all the legends, and use an accent color (yellow or red) very judiciously, only for something that really warrants it. An example would be a switch to activate a fire suppression system, or an ejection handle, but I don't think you have either of those? ;) Also, double-check that you have sufficient clearance between the switch holes and legends, so that the nuts that hold the switch bushings in place don't cover up the legends. Hope that helps. -Roee |
CoPi PTT button?
Hi Andrew,
just one thought you might want to add a push to talk button on the CoPi side in case you don't want the CoPi to have the hand on the stick while you fly. Regards Michael |
Looks like you are planning some type of electronic ignition? In standard Lycoming set up you start on left mag, I see right is marked 'start'. Is there a starter button somewhere?
Never mind, I get it. Right is off for start. I guess starter button is just right of mag switch, not labeled. |
Andrew,
Congratulations on getting to this point. Not sure why you are going with individual back up instruments vs. something like a Gemini EFIS. They are under $1,300 and you have a full six pack in a single EFIS that can be powered by a small dedicated back up battery pack for hours on end w/o ships power. I have on in my 8A to back up my dual G3X and love it. (lower right) ![]() I see you have worked hard on symmetry but it seems to me that your farthest left switch hole should not extend further left than the left edge of your PFD. It just looks wrong to me. Since I have decided to spend your hard earned cash I would suggest you look hard at the possibility of swapping out the GTN650 for a GTN750 and then remote mounting the transponder. I know, I know it's more expensive for sure but that is a single pain vs. years of large screen joy, functionality and added resale. I have played with both for hours and really prefer the large screen GTN750. I echo other comments on 3rd party panels. Aerosport panels are a really nice upgrade but that is your call. One last comment. A Whisky Compass really? UGH, I hate having anything obstruct the windscreen view. Especially something you are never likely to need. If for some reason you feel you NEED a mechanical compass to back up your 3 other compasses then I suggest a panel mounted compass to keep your windscreen view clear. |
Panel
You may want to think about installing idiot lights that will indicate when your doors are not fully latched. I was in an RV10 where the door departed on takeoff due to not being fully latched in the back. We had a safe landing and now sensors and idiot lights are now present in the panel on that airplane. A mi or but very important mod to your design. You also may want to cut in a glove box since you have the room. Looks great! |
Like Cubdriver states idiot lights for the doors are a must. My G3X and I'm sure your AFS will allow a discrete in for CAS messages. Mine is a big red annunciator that comes up on the G3X anytime either a fore or aft pin is not fully engaged. Really easy to wire. Just run one ground wire to Van's prox switches on each side. Closed ground creates the CAS message. I also did this on my remote CO gaurdian. Mine reads "LEFT DOOR OPEN" and "RIGHT DOOR OPEN" and "CO ALERT". You can also create an alert with the message. Makes a clean panel.
You are being too modest. What is needed more than the idiot light, is your safety latch. Then the idiot light shouldn't ever come on (although I still have them installed) bob |
Check out what these guys did with their switches…. Mounted them on a standoff channel so that only the toggle showed on the panel… might solve your label problem ??
http://www.4sierratango.com/panel1.htm pk |
Who is doing the actual CNC machining? We do custom aircraft panels, if it's not too late give us a call
Hi Andrew, I was going to engrave the labels on my panel but in the end I decided to have labels printed onto self adhesive vinyl for greater labelling flexibility....and I'm very glad I did. Engraving is really classy...no doubt about it.....but it absolutely locks you in....and you are virtually certain to want to make changes or additions to the labelling as the actual wiring of the avionics takes place.
I'll give you a few examples of changes I made after the panel was all labelled (none of which I expected). I decided during the actual wiring to make the panel removable so that meant relocating the alternate air vent (change of labelling position). I then decided to put the co-pilot's press-to-talk button on the panel so that it was easier to remove the co-pilot's joystick (new label). After that I decided that I wanted to instal a control wheel steering CWS button on the panel for my autopilot (new label). And so it went. Many unforseen changes. The problem with doing the panel labelling in advance is that quite often you just don't know what you don't know. If that is the case then it might be better to have a labelling system with some flexibility in it. Just a comment for your consideration. |
Engraving
Sorry to hijack this but maybe get some input since it is on the same subject. I am having trouble finding a solution.
I have the Aerosport Symetrical Panel and inserts. They are all cut and drilled for everything, but now need to find somebody that can get them painted or powder coated and engraved with lettering. Do not want to use any stickers of any kind. I am having trouble finding someone that I can have these sent to and get it completed without first trying to learn a software program. Anybody have any ideas on a solution. Thanks Brian |
Engraving the entire panel vs. other options
![]() Sorry for the crappy image quality. If you want to see greater detail, here's my CAD drawing: http://www.kalinskyconsulting.com/rv...l%20layout.pdf P.S. My avionics, not installed in this photo, are: AF-5600 EFIS, above it an annunciator panel of my own design, then from left to right a Gemini PFD, TruTrak/AFS autopilot, Trig TT22 transponder, and below those is a GTN-650. P.P.S. I used Front Panel Express to fabricate my overlay panels, but I used a different tool to design them, not their freebie tool. |
More picky things for you - you're very patient!
1. I tend to have my strobes on all the time, on the ground and in the air. I only fly day VFR, just so that you know. My nav lights aren't very useful for collision avoidance in the daytime so those are usually off. If I'm in any sort of busy area I'll have my landing lights on too. So I'd change the order of those switches, swapping the strobe switch with the nav light switch. 2. The fuel pump, flaps and pitot heat are adjacent. And the fuel pump is adjacent to the flap switch. I'd move the fuel pump and pitot heat elsewhere. I imagine that the fuel pump will be on for every take off and landing, and perhaps the flaps too, so the switch positions are practically reversed. That is, for landing, one is up and the other down. Hate to accidentally mean to put the flaps down and instead shut off the fuel pump. 3. Would a single three-way avionics switch be worth considering? It would have all three positions: off, master and secondary. 4. Also, and here I have no experience except that I sometimes fly with pilots who are capable of acting as pilot in command - is there some sort of easily available autopilot off/on switch available to the copilot? I'm thinking of a single button, not a toggle switch, that would either invoke altitude and heading hold or disconnect that. Some people put something like this on the stick, but since all airplanes with sticks seem to differ, to me that's an invitation for confusion by the copilot. 5. I agree completely with the earlier suggestion to add storage in the panel. Can't have too much cockpit storage. That said, I am building an RV-3. Dave |
A few more thoughts
- write your checklists and play them against your panel.
- startup is the least important for driving your panel design, because you're on the ground and have tons of time - don't place dangerous switches next to safe switches - make sure your groupings are appropriate. If I had my old AirCam panel to do over, I would have put flaps and fuel pump very close since they were almost always used at the same time. - put important switches, like fuel pump, at the end of the group - it might be possible to make a cheap panel out of 020 to check things out before you cut one in 032 - some panels have primary and secondary attitude indicators that both rely on GPS as inputs to the Kalman filters. Looks like you don't have that issue. - standardization is good. You will bring habits from other planes into your RV, and will take RV habits into other planes - a Boeing guideline was to never use color as the sole indicator of anything. Red and plain toggles, ok, if spacing separates the reds. Red yellow white - cant condone that concept. Good luck! Ed |
Let me know if you need my help....we actually do laser engraving for a few RV manufactures. Besides anodizing, we can laser engrave or CNC route painted or powder coated panels or parts, as well as offer several other options from painted-on lettering, vinyl die-cut lettering, or custom name plates from metal or plastics. Lots of options and we never make you learn any software....you have more import things to do....like wiring. :D |
Fantastic information
The info that is coming up on this thread is fantastic. The ideas have definitely already influenced some of the switch locations and made me question heavily some of the approaches.
This is not to say I have changed everything, however, it is great to get a mix of pragmatism, experience and feel. The discussions around colour, position and approach are just great. Hopefully I will have a final design by end of next week ready for submission. I am realistic that his panel may change in future, however, I have allowed for some "expansion" space for other switch gear for short term changes. I still have some stuff to mull over and this should gel over the weekend. Keep it coming, I'm loving it. |
New Version - getting there
I have added a new version of the panel to the thread. Some major changes including fitout for remote transponder. Still awaiting some feedback on alternate product for final decision.
Please take a look and comment. |
Looks great Andrew
Will it be IFR? lol, sorry mate :D |
I like the movement of the transponder, but I agree with the post on making that a standard 2.25" hole for future compatibility. Also, I would like to see the GPS and auto pilot closer to the pilot, but that would split the screens. I don't see the need to split the radio stack as you have. I always put them in as a single cutout and use aluminum angles to hold it all together and to the panel. You may wish you had the extra space down the road.
Overall looks like a nice layout. |
Garmin 750
Just a thought. You've got a bunch of money in the panel already and you have room, why not go with the 750? You can remote mount your Transponder and audio panel to make the panel even cleaner.
You can do a 3 position switch for your Pos and Strobes. This way you can use a combination of your choice and save one switch. Looks good. |
Unfortunately not that much money in the bank account. :-)
However, new modifications complete. I need to look at panel spacing for the Garmin and PAR100EX, may be a final change. And another update: https://dl.dropbox.com/u/95034127/2012_02_05_Font_B.pdf Modified the font to see if this provides an easier readability. Spaced the writing a little further from the switches. Needed to add back the transponder due to certification requirements of ADS-B altitude encoding for 2020. Unfortunately due to space and screw holes, needs to be central. Am happy with that as the primary instruments for backup, Airspeed, AH, Altimeter and Compass all in same position. Modified colurs so that they have more contrast. Quote:
I really like putting the switches above the Pfds.
Hi Dan,
Do you have some pictures I can look at. Quote:
Final Panel submitted
Hi all,
Final Panel submitted. Final Panel: https://dl.dropbox.com/u/95034127/20130210_Final.pdf I have now completed the panel and it is being submitted to Front Panels Express. They have been GREAT!!!! Extremely happy with thier service. Adrian = excellent :-) The configuration has changed somewhat, I am now incorporating the Dynon Transponder unit instead of the Trig-22, and have added some additional content. I want to thank everyone for helping me get to here. The information and discussion has been INVALUABLE. If anyone wants a copy of the panel file OR wants any of the macro objects I created for the purpose. Just drop me an email. I would be glad to help. |
Just wait until the panel arrives, not only will they look great, but you'll get a little treat too!
Panel Update
Hi All,
Well I have an update which is very disturbing...... BUT is still in discussions!!! I was quoted including shipping a decent price, which included all of the cutouts, infill etc.... Agreed with the quote, sent my credit card and waited eagerly.... :) I received an email today that basically said, "we have completed your order, BUT you have to pay TWICE the value for the panel as we stuffed up with the postage costs" :mad: Now this would not necessarily be a problem if I was in USA, however, being in Australia, this is a big thing, which I requested at the front of the process.... Postage went from $40 up to $350..... Yep, That's right an increase of nearly 900%..... :eek: NOTE: I have since found out that USPS basically stiffed them and now they need to discuss the best course of action with me. NOW, given that the panel has already been produced and is awaiting postage, I was happy to increase my payment to cover all of the postage costs, so that I get a panel and it does not cost Panel Express anything more than it has already. My interpretation of the initial response: Sorry, but we would rather throw away the already completed panel rather than post it to you for the postage costs. NOTE: This is currently in discussion as the end result is yet to be finalised. : It seems the email sent from FPE did not quite convey the correct sentiments. I could not for the life of me understand why a company: a) that has stuffed up, and produced a custom item that they cannot use or on-sell, would rather throw it away than make a customer happy???? b) would rather get BAD press, not accept thier responsability and impact thier business rather than gain the GOOD press from doing the morally right thing????? As I have said to them, I am happy to cover the costs of postage, just not pay more than I could have got it produced here in Australia. Especially after having me spend all of my time developing it on thier softweare which is NON-TRANSFERABLE to any other product....... I am sorry, but can someone explain why this is occuring? However, as discussed, this is still in discussions and maybe the end result will be a reasonable outcome. :o UPDATE!!!! After some excellent discussions with Scott from FPE, he has more than come to the party , conveying his concern at the current status. He has advise me that the original order with be honoured and the panel sent for the original price, abliet through an alternate supplier. Thanks Scott, Faith restored.... Fere to the rest of this thread for detailed update. |
Andrew, I'll contact you on PM and see if I can help.
Nice looking panel.
I have an AFS in my -7 and it is fantastic. I have been toying with the idea of updating it to a 5500. However..... Im assuming you are planning on IFR. There is a reasonable amount of debate whether you will be able to get an IFR CofA with non certified (TSOd) instruments shortly in Oz under proposed CAO 20.18 changes. Ive mothballed my panel upgrade for now and shelved my -10 build due to reg uncertainty. May be worth checkin out before you cut the really big cheque (check:)) cheers |
IFR in Oz
Hi Richard,
Yes, designed for IFR. Yep, that IFR in Oz is a bad situation. I am part of a working party with SAAA to try and address this issue with some constructive approaches to ensure IFR for Experimental continues. We are looking at maintaining the existing regime and/or proposing another methodology to ensure safe skies for everyone. Our primary issue is that the old TSO'd gear is actually LESS safe than the existing equipment. Hopefully we can address this successfully and make sure that the future of aviation is safer, not less so due to bureaucracy... |
WHAT...???
If that was my panel, I'd verify that they really wanted to this (break their promise to you), then block my CC, let them throw away the panel, order a new one from Vans, have Vans ship the new panel directly to someone who can cut out your panel AND who'll stand behind their word and then move on...
NO sense doing business with people who doesn't keep their promises. :mad: Let's know how it turns out please? It'll be very interesting to hear about the final outcome. :eek: |
I agree with Alf. Andrew, if anything, you are being too forgiving of their poor business conduct. Mistakes like this happen, and they admitted it was their mistake in generating the quote. Ok. But as such, they need to suck it up and deliver what they promised you at the cost they quoted you, even if at a loss to them. Anything less will leave you short-changed. As even if you simply walk away from them at this point, you've already invested much time and effort in their offering based on that quote.
For what it's worth, I've spent hundreds of dollars with that outfit over the past few months (for my instrument panel overlays and a few other items), and to this point I had been happy with their service. I've recommended them to others, and have even considered using them in the future as a supplier for my business. With your issue pending, I can no longer recommend them, and I'm having serious doubts about them as a vendor I could rely on for my business. That's really disappointing. I hope they understand that by not making this right in your case, they'll be losing more business than just yours. If you think it may be helpful, feel free to forward this message to them. |
| All times are GMT -6. The time now is 04:05 PM. |
