VAF Forums
-   -   Engine cooling tutorial (https://vansairforce.net/community/showthread.php?t=929)
Davepar 03-17-2005 04:50 PM
I was doing some reading over on AVweb and found this useful tutorial on engine cooling and baffling: http://www.avweb.com/news/columns/188945-1.html.
I've got a while before I'll be into the baffles, but I thought this article was an excellent intro to the topic.
Dave
painless 03-17-2005 05:27 PM
Excellent post Dave. And quite timely too, as I am about to install my last section of baffle seal. Van's baffle kit does a very good job fitting to my O320 engine, IMHO.
This is the kind of post that makes these forums so valuable. Atta boy, Dave! :D
gmcjetpilot 03-17-2005 07:19 PM
Plenum
The debate, Why is a plenum more efficient than stock per-plans seal set-up? It is because soft seals, no matter how well done (RV or Cessna) will never be quite as well sealed as a dedicated top on the baffling (ie plenum). Also seals wear out over time. The second advantage is the top on the baffle (plenum) supports the normally unsupported top edge of the baffle, which my reduce baffle fatigue cracking. Just my Opinion. :eek: Combine a plenum with a tight leak free connection the (cowl) air-inlets, you can cut down the inlet stock area, because you are using all the air, loosing little if anything to leakage. That equals less cooling drag and increased speed with no loss in cooling or even improved cooling over soft seals. :D Cheers George
