VAF Forums
-   -   Ferrous Metal in Oil Filter (https://vansairforce.net/community/showthread.php?t=92649)
DanBaier 11-02-2012 09:47 AM
Just went through this with my Cherokee motor.
This is what my cam lobes looked like -
And the tappets (ugh!) -
It was time. Doing it early is less costly than watchful waiting. BTW, the Lycoming school was great for doing the work (with an IA supervising & signing off).
Dan
Kwright 11-02-2012 10:10 AM
Why not follow "local in the business" advice?
The engine sat from the date of overhual, July 1999, until date first flown, in January 2010. During that time it was in a preserved state and in a dry climate. So, not sure it strictly meets the criteria of an inactive engine. Since first flown it has flown weekly. If I could I would fly it every day, but increasing fuel costs require some curtailment of my flight activities.
I have flown 8 hours out of the recommended 10. It's not only the local business recommendation but it is also what I believe the Lycoming recommends (Lycoming Flyer, pg 80). However, that does't make it any easier to fly those hours when it is also stated that metal in screens and filter can lead to catastrophic failure (ibid). This is something that I take seriously.
I am trying my best to employ a logical Risk Management process here and as I interprete the data it now indicats that risk increases on every hour flown until the source and extent of the abnormal condition is known. The worst case senerio, catastrophic failure, is unacceptable. Granted, "On small amount of shiny flakes or small amounts of short hair-like bits of magnetic material. Experiance has shown that engines are sometimes pulled unnecessarily." (ibid)
rocketbob 11-02-2012 10:32 AM
Pulling a cylinder to have a looksee is really not a big deal. We're not talking about a complete teardown.
krw5927 11-02-2012 10:43 AM
Which Cylinder?
So if one wanted to get the best look possible at the tappets and cam lobes, would the #2 or #3 cylinder come off? Or does it matter which one?
rocketbob 11-02-2012 11:02 AM
For me it doesn't matter since I have a borescope. But I would go with #2.
Kwright 11-08-2012 03:21 PM
Additional relevant information
Originally Posted by mahlon_r (Post 317587)
Dean,
The camshaft - tappet face is an extremely critical area in the engine. Minor rust pitting is a formula for spalling, which in turn eventually ruins the cam and it?s corresponding tappet or tappets. Some shops/mechanics will be more tolerant in this area, then others but all should be very careful in this area. So what one mechanic might pass, another might fail. There is no cut and dried tolerance . . . What you consider minor or insignificant, very well might be and then again it might be very bad. . . .In most cases rust pitting and the eventual spalling it causes, isn?t a catastrophic failure type thing. It is a relatively slow cancer that will ruin the cam and very likely other parts in the engine, if the cam situation is left to blossom from its initial stages.
To repair a spalled camshaft requires the same amount of work and initial expense of the prop strike inspection you just had done. The engine has to come all the way apart and if nothing else has been affected by the cam failure you just replace the cam, tappets, bearings, rod nuts and bolts and gaskets. If the pistons are shot with metal impregnation they too must go and sometimes also oil pumps are scored and possibly crankshaft journals can suffer significantly as well. So there are other financial internal risks other then just the cam and tappets if it is left to progress. So fixing a bad cam is very expensive, to say the least. . . .
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Mahlon's insight from another thread appears approprite and will not be overlooked.
I continue to review available information and have noticed a difference in the way Champion and Lycoming recommend that a oil filter should be examined. Lycoming recommends spreading the element out and examin. Because the metal is so small and fine, Had followed that procedure I would not have found the metal. It was not until I used a magnet that metal became apparent.
I did find one NTSB accident involving sudden engine stoppage of a O 360 on an RV-6. It occurred in March 2012, in Bow, WA. Only a preliminary report is available. Though Washington is in a more corrosive moist area than mine, it may be relevant to the metal in oil filter issue.
Doug 11-08-2012 09:14 PM
I'll ask questions rather than speculating since I know very little about these engines:
1. Does the filter inspection require flushing the filter element through a filter paper? I have not heard anyone else doing so and was not shown to do it this way. Is this normal procedure? It seems rather extreme and may be over indicating the problem.
2. You say you are using no additives in the oil, but have you recently switched to a detergent type oil? Ie from straight mineral to W100 or W100+. If so then you may have released a buildup of sludge which may have trapped some of this. I did read a Lycoming sb that delt with this issue, iirc they required an oil change after 5 hours because of the release of the sludge and what it contained.
That said, if I were in your boots I would probably get a specialist to look over my shoulder while I pulled a couple of cylinders to inspect the cam and lifters.
Good luck,
Kwright 11-09-2012 06:27 AM
Filter examination procedure and change in type of oil
From Champion AV-6R http://www.championaerospace.com/***...R-Nov2004.pdf:
Use the following recommended procedures to inspect full- flow oil filters.
? Remove the filter from the engine and place it on a drain tray. Allow oil to drain through a clean cloth to determine if foreign material drains from the filter.
? Using the Champion CT-923 Can Cutter, open the filter . . . .
? Using a clean plastic bucket containing approximately one pint of clean Varsol, swish the filter element around in the Varsol to loosen entrapped metal or other contaminants.
? Using a clean magnet, work the magnet around in the Varsol. Ferrous metal particles in the solution should adhere to the magnet for inspection.
? After all ferrous metal particles have been retrieved with the magnet, pour the remaining Varsol through another clean shop rag, and any nonferrous metals should be detectable in bright light.
This is certainly a more substantial examination of the filter than that described in Lycoming Service Instrction No. 1492D. However, I am unable to determine if it is "over indicating the problem."
Phillips XC 20W 50 has been used since overhaul.
JonJay 11-09-2012 09:01 AM
I do exactly this but take it one step further and cut out the filter paper and run the magnet through the pleats. I do not believe you can over indicate. Your always making metal, but on a healthy engine, it ain't much. My 500SN I0-360 has never shown anything, nada, not, nothing. My 2300SN 0320 consistantly shows very small amounts, less than an 1/8"circle of stuff when consolidated.
You will play **** getting the metal off the magnet. I cover mine with a thin piece of surgical glove.
bkilby 11-09-2012 09:14 AM
There is a good EAA Video on Oil filter removal, inspection, installation.. it's 9 minutes.
http://bcove.me/qxaiqkdw
