Torque steel bolt into aluminum casting
Hi,
I'm mounting the prop governor with an AN5 bolt into aluminum threads. Does anyone have info on torque specs? Thanks, |
Check your thread pitch before you do that. There is also a Lycoming document that covers it. Unfortunately, it is not at hand. Maybe somebody else can provide a link for you.
bolts
Tom, I am pretty sure those bolts are course thread. Also check lyc. service instruction 1438a (plate lw-12347 & two 72053 gaskets) to see if it applies to your applications. It applies to my engine as I am adding it now to fix an oil leak @ 51 hours. Ron
| All times are GMT -6. The time now is 01:58 PM. |
