Eliminating Bendix D2000/3000 Magnetos
My (very) detailed write up of my project to eliminate the Bendix 3000 and associated single points of failure in ignition systems is here: https://dl.dropbox.com/u/12196944/El...g%20D3000.docx
In short this involved the replacement of the D3000 "dual mag" with a regular Bendix mag mounted on a D3000 impulse coupling/gear and an electronic ignition system from EFII/Protek. Works great so far. Will update the writeup with pictures and detailed before/after performance data in a week or so. |
Waiting for your update. Should be good. :o:)
3000
I'm in the process of changing out my Bendix 3000 Dual Mag with the EFII/Protek totally redundant dual Electronic ECU's/pickups/batteries, etc. I chose not to go with the one mag/one electronic conversion.
Robert sure puts out a nice set-up, and with this particular kit, he sends along a dowel thats attached to the mag hole cover plate that plugs the mag pilot shaft bearing hole drilled into the crankcase. (This is hard for you two mag guys to envision but it's necessary for the "D" suffix engines.) It's been hot here and I've had 3 days of interruption this week so it's going a lot slower than I would like.:( Will report later. |
Thank you for the detailed info.
I have the same Bendix magneto and would like to know the weight difference between the 2 setups. This Dual mag is so heavy.... Thanks Denis |
Florida
I haven't weighed any of the components yet but subjectively, I'm guessing my system will weigh about 10 to 12 lbs. more because I'm adding an Odyssey 625 backup battery to assure total redundancy. I did put the battery aft to help with my already forward cg. |
Some comparative data
From two legs I did this weekend.
https://dl.dropbox.com/u/12196944/En...rformance.xlsx I have noticed that my fuel burn might be a little better and I have also noticed EGT's down. Not so much data to go on yet. |
Mag Drop
Walkman
Just completed same, EIGH 1 from Protek and single mag. 0320-H2AD I'm getting a drop of about 250 rpm from both to EI only No miss, idles 750 rpm w/ both will only idle 400 rpm w/ EI only. Check all connections. What is yor Mag Drop MG |
Can you give some details of the single mag p/n you used for the conversion. The bendix single mag needs to have right hand rotation to suit the H2AD. Did you find a suitable mag ( they all seem to be left rotation) or did you have a mag shop convert one to right hand rotation? Did you use the original mag drive gear/coupling setup or something modified? Are you using an impulse coupling on the mag to start the engine or are you starting on the EI? Thanks in advance for any help Regards Graham RV6-H2AD |
| All times are GMT -6. The time now is 11:57 AM. |
