Another red cube leak
I thought I smelled a faint fuel smell a couple times recently on takeoff and landing. I'm paranoid about fuel leaks, so thought I was crazy, but decided to open up the tunnel, and sure enough, I have a very small leak at the NPT threads on the "red cube" fuel flow sender, as has been reported by others previously. I know this is a recent occurrence, at 147 hours. I'm curious how often this is happening to others. I'd used fuel lube on it before tightening. What have others used?
Incidentally, I think every tapered thread fitting in a high-pressure application on the airplane has leaked: oil cooler, brakes, and now this. Haven't had any other leaks on the airplane. Just another reminder to be vigilant. I don't get to fly for a month anyway, as I just dropped it off for paint at 52F this morning! -Rob |
fuel lube is not a sealant
Use Permatex aviation form a gasket. You won't have leaks.
Gary Specketer |
I had the same problem ...
The inlet side of my red cube would not seal tight with fuel lube, even at ugly hi torques. I finally pulled it out, cleaned the threads completely, and reinstalled with #2 Perrmatex. That fixed it.
Maybe I'm wayyyy out of line--
but is seems that the red cubes could have AN threads with oring boss sealing.
Tom |
Mine has never leaked a drop.
Used fuel lube on the threads. The max torque listed in the directions of 25ft lbs won't do it. While I did not design the thing, I think that torque listed is a hold over from the older Flowscan directions. Exceed at your own risk. Quote from the factory man: Quote:
Pro Seal
http://www.vansairforce.com/communit...l+smell&page=6
I think those threads are not cut deep enough that's the only reason a NPT does not seal. Mine was certainly torqued enough and the last place I expected a fuel leak. Proseal will do the job. You'll never have to remove those nipples again and if you did, pro seal has no shear strength and in fact protects the threads very nicely. |
I've had good luck with "Tite Seal".
ok I'm going to scream. :)
FUEL LUBE IS A LUBRICANT. IT'S NOT A SEALANT. I can't count the number of times people have wasted their time with fuel lube on threads, but its one of those things that just wont go away. |
Thanks, guys...
Regarding the fuel lube/sealant issue: aren't tapered pipe threads supposed to seal themselves? -Rob |
think water pipe...
| All times are GMT -6. The time now is 04:58 PM. |
