I will show you mine if you show me yours.
What are builders doing at this interference point? fwd top skin is binding against backing flange.
Get out the cutter
Scott,
I cut a slice out of the frame where the contact occurs. You can put MWH tape there but the slice worked fine on mine. On numerous RV4 pre-buys I have seen both approaches, more cuts than anything else. Smokey |
I just let it rub.
That is exactly the way mine looks, good question.
Ross Scroggs RV-4 #3911 Locust Grove, GA |
chaffing
we can call that a normal problem on the -4. mine does it too.
:rolleyes: antichaffing tape slow the deterioration cheer Michel C-GVFR |
Trim off the bulkhead and forget about it. Unless you like screeching noises when you close the canopy.
Trim it carefully along the pre-scratched guidelines and you won't even have a noticeable gap or air leak. |
| All times are GMT -6. The time now is 02:04 PM. |
