VAF Forums
-   Propellers (https://vansairforce.net/community/forumdisplay.php?f=19)
-   -   Vari-Prop...anyone use them? (https://vansairforce.net/community/showthread.php?t=90130)
TXFlyGuy 08-22-2012 05:03 PM
A friend of mine bought a 4 blade propeller from Vari-Prop. Until today, I had never heard of them. Does anyone know about this propeller company? Are their props on anyone's airplane? Safety record, or lack thereof?
Inquiring minds want to know! I did a search but the info was almost 6 years old.
PCHunt 08-22-2012 05:49 PM
From Mr. Google
A quick Google search showed:
http://www.variprop.com/contact.html
TXFlyGuy 08-22-2012 05:52 PM
Thank you. I have contacted them, but have no feedback from actual customers or other info. I would consider their propeller as an option, but need more info. I have seen too many pictures of what happens when a prop slings a blade into outer space...not pretty.
Snowflake 08-22-2012 05:57 PM
Interesting idea, especially for people with solid cranks. Looks like wood blades, so they'd need metal leading edges if you think rain might be along your flightpath. There is a picture of one mounted on a -6A or -7A on the webpage, and the page is dated 2007, so surely there are some in-flight reports by now...
TXFlyGuy 08-22-2012 06:13 PM
The owner, Larry Morgan said there are a number of RV's and other planes flying with his prop. Just can't find any solid information on their performance and history. My friend bought one...sure hope he chose wisely.
ccrawford 08-22-2012 09:34 PM
I have one of their props (3 blade), but ain't flying yet. The props themselves are made by Props Inc (I think). They do have a solid epoxy edge.
The controller is nice and simple, but does require some extra plumbing for the hydraulic line (not as nice and simple as using the oil pressure from the engine). Where to mount the master cylinder can cause a nuisance too (mine is between the panel and the firewall).
Snowflake 08-22-2012 09:43 PM
Corey, how is the hydraulic pressure conveyed to the hub? Some kind of sliding collar?
deej 08-23-2012 09:35 AM
Any idea of the cost? I could not find any pricing info on their website.
2bolts 08-23-2012 09:48 AM
Apart from the advertising, their site isn't very good at all. But an interesting idea. I'd think about it when the time came.
TXFlyGuy 08-23-2012 10:40 AM
As my friend already owns one, I just wish there were more details on this prop available to research. Can't find anything...and, yes, I am thinking about it. They will custom make the blades to your specs.
whiskeypapa 08-23-2012 11:23 AM
YouTube
Search "Variprop" on YouTube and you'll find a nice little video by one of the canard folks.
YellerDaisy 08-23-2012 11:28 AM
Sorry, I can't answer your question. However; Pat Panzera did a write-up on this hub in Contact! issue #89 back in 2007. I've never talked to any that actually flew with it.
ccrawford 08-23-2012 12:18 PM
Here's a picture:
You can see the center piston (for lack of a better word), which manages the pitch of the blades. There is a pin at the end of each blade that slots into the piston. The hydraulic pressure comes in through the sliding collar at the base of the hub, you can see the hole from the threaded fitting. (You have to secure the fitting so it doesn't rotate, which may or may not be easy depending what you can use as a mounting point for a custom bracket).
Here's a picture of one of my blades:
rv6ejguy 08-23-2012 12:52 PM
I believe Mark Sletten and Kelly Landrum are both flying these props on Subaru powered aircraft.
timothywhigginbotham 08-23-2012 02:10 PM
[quote=ccrawford]I have one of their props (3 blade), but ain't flying yet. The props themselves are made by Props Inc (I think). They do have a solid epoxy edge.
Yes, that sure looks like a Props Inc blade. Mine also had the solid epoxy edge. The blade root looks similar to the one I had also.
Please be careful. Review the thread below to understand my concern.
http://www.vansairforce.com/communit...ad.php?t=62775
I now have 100 hours on my RV-4 with a Catto, 2-blade. I am very satisfied with the Catto.
2bolts 08-23-2012 02:41 PM
[quote=timothywhigginbotham;692555]
Having read that thread, I might be changing my mind about maybe trying this prop.
TXFlyGuy 08-23-2012 02:53 PM
The particular prop in question is a 4 blade 88" hydraulic constant speed prop. Wonder if that makes any difference?
rv6ejguy 08-23-2012 03:03 PM
Props are highly stressed components and like most things in experimental aviation, it is rarely a good idea to be one of the first to buy any new device on the market until the fleet has garnered a bunch of trouble free flight time. We have seen this so many times before on all sorts of components.
A prop failure can kill you and/or wreck your engine or plane. I can think of at least 6 new brands which have had catastrophic failures in the last decade. Stick to proven stuff, let someone else do the beta testing on new prop designs.
TXFlyGuy 08-23-2012 03:30 PM
I agree 100%! Unfortunately, my friends by default have become test pilots without any parachute. Just spoke with the owner of the company...he claims the RV-4 accident was a result of user abuse. You can be your own judge.
timothywhigginbotham 08-23-2012 08:10 PM
Owner of the RV-4
I am the owner of the RV-4. Less than 2 hours on the prop when it failed. Both blades failed at the wooden blade-root. Please read the entire thread if you are considering this manufacturer.
If Jeff Bertuleit @ Props INC (or anyone else) made that statement, it's not true. He is probably referring to the RV-8 in OK that also lost a blade in-flight. The RV-8 was totaled and the owner was injured. Jeff got us mixed up repeatedly. He even sent my prop to the guy in OK by mistake. Jeff did feel one of the other props was abused because the owner planned to operate up to 3000 RPM. My prop never exceeded 2640 RPM before the event. My engine sure did when the prop came off though. Lots of damage to the valve train and other stuff.
I understand there was also a third prop that failed. At one point Jeff was being sued over this. I chose to not participate in a lawsuit. My insurance carrier indicated they may pursue damages.
I am not referring to the hub design. I have no experience with it. The wooden prop blade in the picture looks identical to the one I lost...
I had no knowledge of the other two Props INC failures before my 1st flight. I have nothing to gain or lose at this point. We don?t put the big experimental sticker on for nothing. You get to decide for yourself.
TXFlyGuy 08-23-2012 08:14 PM
I have now eliminated Vari-Prop from my list of manufacturers. Thanks for your input...you must count your blessings every day!
ccrawford 08-23-2012 08:15 PM
Just for further info, I had seen that thread before which is very interesting. Vari-Prop uses their own blade retention mechanism (not the weird compression, whatever-it-is system the ground adjustable hub from Props Inc uses). There are 3-4 lag bolts going directly into the blade body which are epoxied in. The lag bolts fix a metal retaining ring around the base of the blade, which I believe is also epoxied.
I don't have a good picture of that, but I can get one if anyone is interested.
There are some folks successfully flying with these (and apparently lots of airboats), but certainly not as many as the mainstream brands.
smokyray 08-24-2012 11:32 AM
Testing, testing...
I have seen two in current operation installed on local airboats, both with composite blades per the website. Both had no apparent issues...
Smokey
FYI, The hub/blade system VariProp uses and the ill fated Props Inc system previously mentioned are two completely different animals.
TXFlyGuy 08-24-2012 11:52 AM
Smokey
Perhaps I should reconsider...but their props are wood, maple I think.
N941WR 08-24-2012 01:06 PM
A number of the composite props us wood cores. Catto even uses a maple wood core. The difference is in how they are made.
David Z 08-24-2012 05:54 PM
MT
MT uses a wood core in their composite blades as well. I saw a cut-away of a MT blade once, and it was quite interesting.
smokyray 08-27-2012 02:00 PM
Prop me up...
Myron,
Having been down the prop trail nine times and seen the current available options out there my choices for Ground adjustable based on inputs from friends flying them FYI:
1. Whirlwind GA (all composite blades)
2. Sensenich GA (all composite blades)
My favorites I flew many hours, owned and tested.
1. Catto 2 Blade wood/composite with nickel leading edges. www.cattoprops.com
2. MT Fixed Pitch wood/composite http://www.mt-propellerusa.com/en/mtusa/products.htm
3. Gary Hertzler wood/composite hertzler@yahoo.com
V/R
Smokey
TXFlyGuy 08-29-2012 08:59 PM
Originally Posted by smokyray (Post 693700)
Myron,
V/R
Smokey
Thanks! This prop is a 4 blade 88" paddle prop that is constant speed hydraulically operated.
Jimauman 12-05-2016 07:07 AM
Well, it is now 4 years later.
What are any of you doing with Vari-Prop?
Is anyone actually flying one successfully?
Capt Jim
scrollF4 12-05-2016 07:31 AM
The variprop.com URL is for sale on GoDaddy. I don't expect to see much customer support.
ccrawford 12-05-2016 01:51 PM
I gave up on mine. I couldn't get comfortable with how the individual blades sit in the hub and the mechanical link to rotate the blades. If you are a better ME than me (likely!) then you might be able to modify it slightly to be reliable.
I still have it if you want to check it out, I'll sell it to you cheap cheap.
