Just for further info, I had seen that thread before which is very interesting. Vari-Prop uses their own blade retention mechanism (not the weird compression, whatever-it-is system the ground adjustable hub from Props Inc uses). There are 3-4 lag bolts going directly into the blade body which are epoxied in. The lag bolts fix a metal retaining ring around the base of the blade, which I believe is also epoxied.
I don't have a good picture of that, but I can get one if anyone is interested. There are some folks successfully flying with these (and apparently lots of airboats), but certainly not as many as the mainstream brands. |
Testing, testing...
I have seen two in current operation installed on local airboats, both with composite blades per the website. Both had no apparent issues...
Smokey http://www.variprop.com/ FYI, The hub/blade system VariProp uses and the ill fated Props Inc system previously mentioned are two completely different animals. |
MT
MT uses a wood core in their composite blades as well. I saw a cut-away of a MT blade once, and it was quite interesting.
Prop me up...
Having been down the prop trail nine times and seen the current available options out there my choices for Ground adjustable based on inputs from friends flying them FYI: 1. Whirlwind GA (all composite blades) 2. Sensenich GA (all composite blades) My favorites I flew many hours, owned and tested. 1. Catto 2 Blade wood/composite with nickel leading edges. www.cattoprops.com 2. MT Fixed Pitch wood/composite http://www.mt-propellerusa.com/en/mtusa/products.htm 3. Gary Hertzler wood/composite hertzler@yahoo.com V/R Smokey |
What are any of you doing with Vari-Prop? Is anyone actually flying one successfully? Capt Jim |
The variprop.com URL is for sale on GoDaddy. I don't expect to see much customer support.
| All times are GMT -6. The time now is 05:22 AM. |
