VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Decalin bottle leaks and removes paint (https://vansairforce.net/community/showthread.php?t=89265)
BigJohn 07-31-2012 07:10 AM
A warning to all using the fuel additive Decalin. The poor design of the bottle allows seepage out through the cap of the measuring cup at increased temperatures, or decreased air pressure (high altitudes). Ask me how I know! I found out on the Oshkosh trip that Decalin makes a very effective paint remover. I suggest if you carry Decalin in youur airplane that you enclose the bottle in some sort of fluid proof outer container.
Sid Lambert 07-31-2012 07:27 AM
Most octane boosters are just paint thinners.
http://en.wikipedia.org/wiki/Toluene
Neal@F14 07-31-2012 09:08 AM
You don't want the decalin spillage vapors to stand around in stagnant air either...probably not an issue in a flying airplane cockpit with plenty of fresh airflow, but once parked on the ground and sitting with the canopy shut would be a real concern.
http://en.wikipedia.org/wiki/Decalin
Mel 07-31-2012 09:09 AM
Just for conversation sake. Typically paint thinners will not affect fully cured paint.
Decalin is not an octane booster. It's a lead scavenger.
dick seiders 07-31-2012 10:02 AM
Didn't have any problems with mine, but I made certain to tighten caps securely following use. The biggest thrill was pumping in the 100ll. I got splashed on first effort, but had my splashguard cover in place so no problem. I think it took me 10-15 minutes each time I added 10-12 gal. as It would only take about a 1/2" dia. flow into the fill pipe w/o spilling over. Has anyone found a vent remedy?
dick seiders
rvbuilder2002 07-31-2012 10:21 AM
When I carry any liquid such as oil, decalin, etc., in an aircraft, I always put it in a heavy (freezer type) gauge zip-lock back and remove as much air as possible while sealing. It will help prevent this type of thing from happening.
funflying 07-31-2012 12:57 PM
Ship it
I was having the same concern so I took advantage to Aircraft Spruces' free shipping option and will looking for it in the mail soon.
rodeja 07-31-2012 07:08 PM
I thought it was just me. Thank goodness I had the bottle in a ziplock bag. When first using it at refueling I found about a 1/2 cup in the bottom of the bag. Have now packed paper towels under the bottle. We usually fly high and I guess the lids don't seal well. The stuff works, or I wouldn't be messing with it. The bottle needs a redesign though.
MacPara 06-02-2014 10:59 AM
Does anybody have access to a quart size Decalin bottle? I have one at the hangar and am trying to find rough outer dimensions to find a cereal container to put the bottle in - without driving all the way to the hangar.
I don't trust Ziploc bags for long as they tend to develop small leaks in the corners when used continuously. I would allow for some micro-venting at the top of the cereal container to deal with the pressure changes.
Mel 06-02-2014 11:13 AM
My quart size Decalin bottle is 5.5" X 9.25" X 2.5".
