VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Wingtip landing light kit (https://vansairforce.net/community/showthread.php?t=88993)
tomcostanza 07-22-2012 05:17 PM
I started fiting the wingtip landing lights supplied by Van's (with the MR bulbs). There aren't many options for the landing light side, but there are a couple for the nav/strobe light side. The plans say to fit the nav/strobe light directly to the fiberglass. I started painting the mounting surface with metalic paint, but it looks pretty cheezy. I wanted to get the max reflectivity. I was thinking I would fit a piece of alclad over the raw fiberglass, like the landing light side, and paint it white.
What have others done?
Thanks, and clear skies.
jay.pearlman 07-22-2012 08:41 PM
landing light
Why not just polish the alclad and use it as a reflector?
Other have done that if you look at some of the previous posts.
Sam Staton 07-23-2012 03:33 AM
Mirrored plexiglass
This is also an option. Plexiglass is available with a mirrored surface - light, no polishing involved.
byoung 07-24-2012 05:39 PM
Wingtip landing light?
How well do the wingtip landing light systems work? I see many use the Duckworks (SP?) system for landing and taxi lights. Are the wing tip systems worthwhile?
