System drag
Go for a fly and get the airplane to repeat the symptom.Then add enough trim so you have to hand fly it. "load the control system" If the problem goes away, it's elevator related aerodynamic.
I had the same problem. The tires were out of balance and were spinning at higher speeds. I could hit my brakes or slow down and it would stop. Balanced the tires and no more problem.
| All times are GMT -6. The time now is 10:44 PM. |
