VAF Forums
-   -   Hylomar vs EZTurn or Fuel Lube (https://vansairforce.net/community/showthread.php?t=8791)
mlw450802 06-25-2006 06:06 PM
Can anyone offer an experienced opinion of the equivalency of Hylomar Blue sealant and EZTurn?
-mike
abuura 08-10-2006 09:31 AM
I am told Hylomar HPF is no longer available. I call Mattituck and they said they use EZ-Turn (fuellube) for sealing gaskets. The back of the tube indeed says it can be used for sealing gaskets. B&C sticks to their HPF story, but I wouldn't expect them to be experts in the field of gasket sealants.
Jconard 08-10-2006 09:44 AM
There is also a product called tite seal, which is also specifically designed for aircraft gasket sealing. It is safe and will not harden, so if a chunk gets in the oil, it will not create a clog.
JC
Rick6a 08-10-2006 10:09 AM
Originally Posted by abuura
I am told Hylomar HPF is no longer available............
Having recently purchased some Hylomar for an engine overhaul, I can assure you that Aero in Granite City Il. has both the medium and heavy varieties of Hylomar in stock as we speak. Cannot comment on its virtues as a substitue for EZ Turn though. I'd give em a call and see what their professional opinion is.
http://www.aeroinstock.com/Engine_Pa...nformation.php
dan 08-10-2006 05:06 PM
Haven't used "Hylomar Blue," but if you're using it on fuel fittings or fuel cap gaskets or the like, and it's indeed blue, that might not be the best choice. If I saw blue streaks and didn't know if it was sealant or actually fuel, that could be a pain.
I like that EZ Turn is colorless. In the event I have a leak, I'll see it easily!
abuura 08-10-2006 05:10 PM
Gasked sealants -- no more Hylomar HPF
Preparing to install my SD20 I reviewed B&C's installation instructions. B&C says to use Permatex Hylomar HPF or Loctite; couldn't find either and confirmed with B&C they have no alternate recommendations. The Permatex company website doesn't show Hylomar being available, so I called Mattituck -- who I assume knows something about sealing gaskets -- and was told they use EZ-Turn (Fuelube). Sure enough, it says on the back of the tube that it is suited to gasket sealing. Also was told they use a rubber roller to put a thin coating on gaskets. In a later conversation with a Permatex engineer, confirmed that Hylomar HPF is no longer available and was told that Permatex 97 High Tack is an acceptable substitute. So, armed with my trusty tube of EZ-Turn and a roll of scotch tape and spindle from a dispenser to spread it on the gasket (instead of an $11 roller), installed the SD20. By the way, the SD20's inboard lower nut is hard to reach with the engine off the mounts and even with a crowfoot wrench I had to SWAG the torque; reaching and torquing this fitting properly when the engine is hung looks to be a time-consuming and frustrating endeavor.
mlw450802 08-10-2006 06:41 PM
I don't think Permatex had anything to do with Hylomar.:confused:
http://www.hylomar-usa.com/?siconten...ckingid=672078
Do a google search on hylomar and there are lots of hits and many active online sources.
I just recently purchased a tube of hylomar blue within the last month or so.
-mike
mlw450802 08-10-2006 06:58 PM
It is indeed blue and you have an excellent point.
I have discovered though that it is the best air fitting and piping sealant I have ever used! :)
Lloyd 08-08-2007 11:47 AM
Hylomar can be found at Fowlers Engines in Col, OH
cnpeters 08-08-2007 12:02 PM
Can EZ-Turn be found in your usual HD/Lowes stores, or do folks order it from ACS, etc?? Has anyone had mush use for Permatex Red Silicone RTV? Label says for high temp application.
