| alpinelakespilot2000 |
05-31-2012 05:31 PM |
fps setting for Drift HD
I have a first flight imminent (pending weather and test pilot scheduling) and would like to make sure my new Drift HD170 Stealth is set up properly. With 720p selected for the resolution, does anyone have any suggestions about what "frames per second" setting I should use to produce the best video, particularly with the prop spinning in the field of view? (I know I've seen someone make a suggestion related to this somewhere, but can't find it.)
Thanks.
