Landing gear fairing question
I bought the fairings that Van's sells. They were made on a male mold so they are slick on the inside and the outside has the rough fabric weave.
My question is what is the best way to slick them up on the outside? It seems that the options that I can think of are to spread a coat of micro slurry on and sand smooth. I also have some very light glass deck cloth. I could put a layer of this cloth on it and then smooth it over with micro slurry. Any other ideas are welcome. |
Do yourself a favor and send those back and buy these:
http://rvbits.mybigcommerce.com/rv6-...tion-fairings/ They come out of the box ready to paint after you mount em up. |
Ditto
Installed and painted. |
Assuming that I am not going to send them back, does anyone have any good suggestions?
Keep them then AND also order from RVBits, an outstanding product. Coating them with be Flox, super fill, hi fill, or combination thereof will be a lot of work.
Posts 14, 15, 17, and 18. Please accept my compliments....you're attempting to acquire actual airplane building skills among those who apparently only wish to exercise their credit cards. |
Leg fairings
FWIW, I might consider sanding the exterior surface until it is smooth. Goes quickly with the right equipment. The sanding screen for sanding drywall seams works well for me. Rip the screen into 2 x 4 inch strips, fold over a small block of wood, and start recriprocating. Light weight is good. Good luck!
- Roger |
Dan's post 15 holds the magic.
Do not be tempted to add a thick coat versus the three thin coats of raw epoxy. If you do it will likely sag and you will need to go back a step and start over. Add primer only when you are satisfied with the finish - primer does not fill the surface defects. |
Yep, those of us that did not want to spend a fortune in time and money making those peices of poo work and look like something could never have any real aircraft building skills. You better listen to the experts.... |
Ditto....again
Ditto....again, what Brian said. My project got to the point where I just wanted to finish it and not spend endless hours fitting parts that should have fit better in the first place. RVBits fairings are available at:
RVBits full set fairings .... $185 at Cleaveland Tool http://www.cleavelandtoolstore.com/p...number=RV67IF4 Van's are $149 Personally, $36 well spent in time and effort. Not wishing to start a war here DanH as your fiberglass skills are legendary. However, mine are not and after 14+ years of building, I was just itching to fly. He is not building his own fairings as you have done but attempting to fit Van's fairings. Good Luck with that, as many have said. |
| All times are GMT -6. The time now is 12:16 AM. |
