VAF Forums
-   -   Countersunk rivet problems (https://vansairforce.net/community/showthread.php?t=86386)
flyingtaran 05-17-2012 12:21 AM
hi all,
i'm only fairly new to the rv and i've only just started riveting the horizontal stabiliser skin to ribs and i'm encountering problems with my countersunk riveting, I did the first one ok, but now on the second & third i reckon i've probably drilled out and re-riveted them about 10 times, they are just not sitting straight & flush, everytime I drive them they end up sitting up.
this has been doing my head in to a point where i haven't worked on it for a month, any suggestions would be great,
heres a few pics,
taran
FlyingArcher 05-17-2012 02:13 AM
Clamp
Hi Taran,
It would help to know which riveting technique you used here, but based on the parts, I guess you're using a rivet gun with mushroom head + bucking bar.
I think what you see is because your parts were allowed to move during riveting. I would anchor/clamp the assembly to the bench so that when you push on the skin with your gun, it stays in place. Also, don't push hard on the bucking bar, just prevent it from bouncing laterally out of the shop head you're forming.
You should try to find some videos on the net (there are many available, starting by the EAA website) that demonstrate the proper riveting techniques, I can tell you that it really helps. I NEVER had used a rivet gun or squeezer before starting my project and looking at these videos gave me much more confidence.
Hope this helps and don't give up, you'll be an "expert" soon.
RV6AussieNick 05-17-2012 02:29 AM
square to the job
Hi Taran,
Looks to me that you may not be holding the gun square to the job, when you rivet do you see a slight mark next to the rivet, if so this indicates that your gun isn't square to the job, the hitting force is being delivered next to the rivet instead of into it. It may take a few rivets to get your eye in to square the gun up, if you have a rivet helper they might be able to help sight the gun up before riveting.
Richard Connell 05-17-2012 05:09 AM
Gday Taran,
Are you riveting by yourself?
This looks like the rivet gun is bouncing on the surface allowing the rivet to compress on the wrong side. The outside. And possibly between the rib and skin as well.
You need more force holding the rivet gun than the bucking bar- so the bucking bar does all the bouncing, not the rivet gun.
Where in Sydney are you? I'm happy to pop round and give you a hand sometime if you need.
Cheers
flyenforfun 05-17-2012 06:32 AM
One guy said not holding the rivet gun flush.. not sure if you are doing this or not, but the best flush riveting tool I used on my entire project was the pivoting rivet set for my rivet gun. It is a flat flush rivet set, surrounded with rubber, and its ball mounted so even if you dont have the rivet gun perfectly square, the set will lay flat on the surface.
Anywho, I think maybe you need to push harder with the rivet gun and let the bucking bar bounce a little more, let it to the work. Ive found the less you push with the bucking bar, the faster the rivet goes down, just dont let it bounce around and damage the metal around it.
paul mosher 05-17-2012 08:33 AM
Drilling
If you don't drill the hole straight this is what happens. Use a drill bushing to get it square.
Av8torTom 05-17-2012 08:43 AM
Swivel Head
taran,
Like others have said - looks like you're not holding the rivet gun firmly enought against the machine head of the rivet. When this happens, the bucking bar will push the rivet out back towards the gun. Also, if you don't already have one, I recommend a swivel mushroom rivet set. Allows you to be off slightly getting the gun perpendicular to the work. Don't get discouraged, you'll get there.
Tom
rzbill 05-17-2012 12:17 PM
Gun air pressure?
+1 for comments about bucking bar pressure and clamping of the work such that you can apply hand force to the gun without the workpiece moving.
As a beginner, you have not developed the "feel" yet. Don't worry, I'm sure you will get it quick when you find that sweet spot.
What air pressure is supplied to the gun?
It is possible that it is too high, causing the gun to bounce no matter how much you try to hold it on the work.
For my equipment, around 40-45 psi worked well for #3 rivets. It may be different for you.
I agree with the other comments above, with the small caveat that when I want a rivet REALLY flush, I use a solid set with rubber ring and not the pivoting mushroom set mentioned above. The pivot does make a difference in how hard it hits.
Otherwise the pivoting unit is great for solo riveting.
carrollcw 05-17-2012 01:03 PM
I am also a fairly new builder. Just finishing my empennage. Definitely looks like not enough pressure at the gun / too much pressure at the bucking bar (been there done that).
Also, I too use the swivel flush head with the rubber around it. If you are using it too, you MUST shave down the rubber head so the surface will sit flush on the rivet. Otherwise, the rubber will keep the flush head too far from the surface (unless you use an extreme amt of pressure) and every rivet will turn out that way. If that is the problem, just use your scotchbrite wheel and carefully grind the rubber down flush.
jrs14855 05-17-2012 01:07 PM
rivet gun
The rating of the rivet gun is also a factor. The lower the rating the harder the gun has to work and the more it will move around.
economy gun not rated
2x gun 5/32 rivet
3x 3/16 rivet
4x 1/4 rivet.
I would recommend the 3x
minute2 05-17-2012 03:52 PM
Practice !
Another piece of advice is to practice on samples/scrap pieces, not your airplane. Don't put rivet gun to airplane until you can shoot several perfect rivets (or more). If it has been awhile since I last riveted I will always pound a few practice rivets to get the feel back before I start on my actual rivet job. Also if the rivet job is in a difficult location/position I will recreate it in a practice scenario to make sure I won't have a problem. I hate to drill out rivets, and rarely have to.
Kerry
Greenley 05-17-2012 06:10 PM
The advice I was given that worked well for me was to get some extra AL squares and put in 250 rivets, drill them all out, and redo.
Bill Greenley
Jerry Cochran 05-17-2012 07:55 PM
Put pressure on the head with the gun and let the bucking bar do the work, bouncing a bit... If you have the proper push on the head, no way will the rivet stand up "proud" HTH,
Take some scrap, drill holes and practice, it is a learned thing...We have all done it, especially me...
