c/s prop and governer question
I just purchased a beautiful RV8 - moving up from a 4 !
I want to convert it to a C/S prop and am looking at the Vans Hartzell Blended airfoil 72" 2 blade. Does anyone have input on the type of governer to consider: MT vs. Hartzell? Any advice on the conversion process? Thanks! |
I used the PCU5000 and have been very pleased so far. Very smooth with no surging. http://www.pcu5000.com/
5000
Ditto on the pcu 5000
Governor
I had the MT.
I now have a McCauley. Find a yellow tagged light weight Woodward, McCauley PCu5000 or Hartzell and I think you'll be happy. |
You might also consider the Whirlwind 200RV prop. Do some research and I think that you'll find that the Whirlwind is 'thee' prop of choice when comparing Hartzell/MT/Whirlwind on an RV6/7/8.
http://www.whirlwindaviation.com/props/rvseries.asp In addition, you'll find that most Whirlwind dealers can offer you substantial savings.....this comes in handy when you compare prices between 'the big 3'. I know I offer most of my Whirlwind dealer discount to the customer.....anyway you might shop around. Not sure what Hartzell and MT do in this area......maybe someone who made a purchase can offer some info? Good Luck....you'll love your C/S! Quote:
Really good (or just so so even) prop data is quite hard to find. |
Check Larry Vetterman's Site
Larry has a good comparison of the Hartzell BA and the 200RV. There is no TO or low speed thrust data that I could find on the 200RV and I searched extensively and visited both factories. There are some operating limitations to the 200RV, but not the BA. There are other differences, so knowing what you want is a good start. Happy shopping.
http://www.vettermanexhaust.com/ |
Thanks everyone
It's a decision for sure between the whirlwind and Hartzel blended. I'm wondering if the nose heaviness of the hartzell could be minimized by simply locating my battery in the aft fuselage or is there a good reason for not doing this?
If anyone out there is going to be needing a Sensinich F/P prop with spinner, etc. (like new less than 200 hours) let me know! |
Whirl Wind, MT gov, battery in back.
The Whirl Wind 200RV does not really have any operating limitations like the Hartzell. They say "recommend" in the manual, but if you ask the factory, it is not a restriction. I have the IO-360-A1A, which has a fairly inconvenient limitation on the Hartzell BA(no continuous between 2350-2500 above 24")
I run 2400,24" on my 200RV a lot. No issues. I have the MT governer, nothing at all wrong with it. I would definitely recommend moving the battery to the back. |
| All times are GMT -6. The time now is 06:47 AM. |
