VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   magneto hold-down bolt torque? (https://vansairforce.net/community/showthread.php?t=85982)
Bevan 05-06-2012 02:31 PM
I had to remove a mag to get at a oil hose fitting. Does anyone have a quick reference for the torque spec for the bolts that hold down the magneto? Looks like 5/16 course thread so I'm thinking 160 in lb max but this seems much less tight than they were.
Bevan
TSwezey 05-06-2012 02:50 PM
Bevan
Maybe the last person didn't torque them correctly.
LettersFromFlyoverCountry 05-06-2012 02:57 PM
[quote=Bevan;656516]I had to remove a mag to get at a oil hose fitting. Does anyone have a quick reference for the torque spec for the bolts that hold down the magneto? Looks like 5/16 course thread so I'm thinking 160 in lb max but this seems much less tight than they were.
Bevan[/QUOT
What kind of mag? I looked at this this morning. Bendix was listed as 170-320. Slick was listed at something like 130.
DanBaier 05-06-2012 03:49 PM
Your instincts were right - 170 not enough
204 inch pounds (per Lycoming Table of Limits - page 1-37) - be sure to use a new star washer
Dan
Bevan 05-06-2012 03:50 PM
They are actually P-mags on a Lyc 0-360. The hold down bolts are actually studs embeded in the case. All we are doing is putting nuts on the studs and torquing. I don't know what the original mag type was.
My torque chart for 5/16 coarse bolt is 160 in lb for max. But surely there is a lyc spec for this torque and perhaps it is different. Anyone have a lyc overhaul manual handy and could look it up?
Bevan
Bevan 05-06-2012 04:07 PM
Thanks Dan. :)
Bevan
az_gila 05-06-2012 05:28 PM
This might help for those generic torques for the coarse thread screws on your Lycoming -
NOTE - unlike airframe torques which are quoted dry, these are for lubricated nuts.
