VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Autopilot Stop Bracket? (https://vansairforce.net/community/showthread.php?t=85617)
joedallas 10-10-2015 03:47 PM
is there a servo kit
is there a Garmin servo kit
I can't find it on van's site
Joe Dallas
Originally Posted by Phantom30 (Post 1020667)
There is a minor modification required to the mounting brkts which is covered in the plans.
Phantom30 10-10-2015 05:44 PM
Joe Dallas
Joe...what you need is plans section 44B-1 thru 44B-06. You need part F-00072 to know where to modify existing brackets (grind off in an arc)....easy to do.
The pitch servo rod is different....Dynon is 6-1/4", Garmin is 6-3/16"
There is a wiring change....2 new wires are run from avionics bay to pitch servo plug to replace 2 that get taped off. Hope this helps.
Edit...I got mine from Vans when I ordered my G3X package...give them a call.
joedallas 10-10-2015 05:55 PM
I will call Monday
Joe D
joedallas 10-11-2015 07:28 AM
drawings 44B-1 thru 06
I looked on vans web site for drawings 44B-1 thru 06. and could not find them.
Does any have a link to these drawings
Joe Dallas
JerryH 10-11-2015 07:33 PM
Send Van's support an email and they will email the file to you.
rvbuilder2002 10-12-2015 09:52 AM
Originally Posted by rvbuilder2002 (Post 1020678)
True, but with the RV-12 control system "That has been built correctly"it is impossible for an over center situation on the autopilot servos to occur.
I am updating this post based on new info...
Apparently at least one builder has made, and then installed a servo pushrod of an incorrect length and then complained of a problem with the control system not working properly.
It is difficult to understand how this could occur since the PAP has a complete control system check procedure, along with an autopilot calibration procedure that requires that the control stick be moved to all extremes of control travel....:rolleyes:
