VAF Forums
-   Electronic Ignition Systems (https://vansairforce.net/community/forumdisplay.php?f=103)
-   -   PMags and G3X (https://vansairforce.net/community/showthread.php?t=84660)
azonic75 04-03-2012 01:45 PM
PMags and G3X
I'm wiring my engine monitoring system and was wondering what people are using for their tach output.
Will the G3x read the tach output off the Pmags? One or both?
Kai
g3xpert 04-03-2012 02:21 PM
Hello Kai,
Yes, the G3X system is compatible with the tach output from various electronic ignitions systems, including the P-Mag. Since the P-Mag tach signal is available regardless of whether or not its P-lead input is grounded, you really only need to connect the tach output from one P-Mag.
For dual electronic ignition system installations using ignitions other than the P-Mag, you canconnect the tach outputs from both ignitions as shown in Figure H-1.2 of the G3X Install Manual and the system will use whichever RPM signal is the higher of the two.
thanks,
- Matt
Ironflight 04-03-2012 04:53 PM
As Matt said - it works great! I connected both before I realized that the P-Mags worked as Matt explained - just more redundancy I guess.
azonic75 04-03-2012 06:46 PM
Thanks guys.
Paul,
Did you use the ammeter shunts supplied with the kit or go will Hall effect sensors?
Kai
Ironflight 04-03-2012 07:12 PM
Originally Posted by azonic75 (Post 646235)
Thanks guys.
Paul,
Kai
I used the shunt - works great!
N941WR 04-03-2012 07:16 PM
If the G3X has two electronic tach inputs, wire them both up.
In my preflight, I not only ground the P-mags but drop power to them as well. In this case, it stops reporting the RPM; however, because I have both of them wired up and I only power one down at a time, I still get a tach reading. This setup is with a Dynon, not a Garmin.
Grim Reaper 04-27-2012 12:49 AM
EI options
Has anyone used an electronic ignition set up that consisted of a LightSpeed III with a P-Mag. Are they compatible? :eek:
Grim
SteinAir 04-27-2012 03:01 PM
Grim
Yes...but in that case the easiest solution is to just hook up the Pmag and be done with it...
Stein
