How do I clean my MA-4-5 carb's screen?
Hi ya'll,
I'm getting ready for my first annual, and I have a noob question: How am I supposed to clean the inlet screen on my carb? I've found this handbook, which has lots of good information - but no specifics on how to remove/replace the screen. From looking at the schematic, I guess:
No need to remove the fuel hose. The inlet strainer comes out from the opposite side. Bend down the tabs on the tabbed copper washer, remove the nut/finger screen. Inspect the screen and clean with a blast of carb cleaner or clean fuel and compressed air. Apply a small amount of fuel lube to the threads and re-install with new tabbed washer. Torque till tight (no idea what exact torque, but you're only dealing with around 4psi fuel pressure anyway so don't go gorilla on it). Bend down the washer tabs to safety the nut and you're done.
Thanks Brian (I'm sure future search users thank you as well ;-)).
Now one more question, does anyone know the part number for that copper washer? If I recall correctly, its oddly shaped. On the AS&S website I see many options: http://www.aircraftspruce.com/menus/ep/carbparts.html |
A&P mechanic
Kevin,
Hire an A&P mechanic for a couple of hours to help you (do) the engine inspection, especially if this is your first one. The FAA says you don't need one, but they never leave the ground, right! :) Lot's of little tricks to engine maintenance and repair that you don't learn while building the airframe. John |
You can reuse the tabbed copper washer by annealing. Heat it to red hot with a torch and drop it in water and voila, good as new.
| All times are GMT -6. The time now is 05:57 PM. |
