VAF Forums
-   -   Canopy Rail Lube (https://vansairforce.net/community/showthread.php?t=83951)
ghatch 03-16-2012 11:46 AM
Canopy Rail Lube
What is anyone using to lube the canopy rails and/or canopy rail rollers on sliders?
I have an RV-7 slider. I live in West Texas and a dusty environment is the norm.
Thanks for your input,
Gerry
F1Boss 03-16-2012 01:26 PM
keep it dry
I think a teflon type lube will be best. Not one of the ones that stays wet, or waxy - one of those that dries up. My wife found a liquid teflon substance that was packaged in what would be an Elmer's glue sort of squeeze bottle (@ Lowe's). Sounds perfect for the wheels, and could be wiped on the spine rail as required. I have not stolen it from the kitchen - yet...:rolleyes:
Carry on!
Mark
Rick_A 03-16-2012 02:27 PM
Bicycle chain lube
I don't remember the brand, but I use a dry type lube that I bought at a bicycle shop.
While you're there, pick up some Tri-flow to use on rod-end bearing and other flight control hinge points.
humptybump 03-16-2012 02:43 PM
My A&P recommended a small amount of silicone spray.
Rosie 03-16-2012 09:28 PM
I live in the Mojave desert and have recommended this before for rod end bearings but also use it on my slider rails: LPS-1 :D Rosie
az_gila 03-16-2012 10:48 PM
Rosie, might not be good in other parts of the country.
I think LPS-1 acts like WD-40, displaces the water and allows the part to rust quicker once it disappears. The description you linked to does say "Provides a short term, light corrosion resistant barrier."
It should be fine in the Mojave and AZ deserts though...:)
Sig600 03-17-2012 04:14 AM
You could try a very small amount of carbon graphite, like whats used in locks, if you're in a dry dusty place.
If you're a gun nut, a tiny amount of CLP will also go a long way to not only lube but protect the exposed metal.
bird 03-17-2012 05:59 AM
I vote for
Triflow. Probably, keeping it clean is the most important part.
bird
flynwest 03-17-2012 07:16 AM
silicone
If you have not painted yet do not use silicone. Your paint will not stick to it. My painter will not allow any silicone in his shop.
ghatch 03-17-2012 08:22 AM
Thanks guys. I have Tri-Flow, LPS 1&2, CLP, CorrosionX. All of which I have used before. I think I will check out the Lowes stuff suggested and the dry lube from bike shop. Everything I have used previously has collected dirt and made the track gritty. I fly from my West Texas grass (dirt if it doesn't rain) which adds to the problem.
Thanks again for all your help,
Gerry
