Running Ethanol with AFP?
A friend of mine said that the AFP people are working on (or already have?) a mod that will allow the use of AGE-85 ethanol with the IO-360s using their system. Does anyone out there (especially you guys at Airflow Performance) have any more details on that project? Sounds very interesting, especially if you can get AGE-85 for less than $4/gallon! (can you? I have no idea.)
We have been working with South Dakota State University on that program. Basicly if you can get the fuel, the fuel injection system can be calibrated to operate with AGE-85. You'll use about 25%-30% more fuel at WOT with this blend. If your system is calibrated to run with the AGE-85 and you wanted to run AVgas you would have to lean the mixture to get proper operation.
Don |
running Ethanol
I don't know about the AFP system, but there is a well known aerobatic pilot/professor at Baylor that has done a lot of research on running Ethanol in injected Lyc engines. I saw a presentation that he gave that included his record setting trans-Altantic crossing running Ethanol on the crossing, but I don't recall his name at the moment. He flys at aerobatics at air shows running Ethanol.
Don, do you know where the SD guys get their ethanol? Who produces/sells it up there?
Jordan,
Try this url. http://www.e85fuel.com/index.php I bought and tested some E85 for vapor pressure. It came in at 56kPa, almost as good as 100LL which usually tests at 62. dd RV-7A N707DD Subaru H6 Flying with about 10% e-gas at this time :) |
Age-85
Found this about AGE-85 in RV Hotels.
Madison - MDS Pearson, Dick - 605.256.4157 Any RV pilots traveling through this part of the country are welcome. We live on Lake Madison, Madison S.D. Identifier-MDS Have plenty of room and hangar space. I have an RV 3A and an RV 6A which I built. Both powered by AGE-85, (aircraft grade ethanol). Dave Wolles 9A finish |
| All times are GMT -6. The time now is 04:35 AM. |
