VAF Forums
-   Interiors (https://vansairforce.net/community/forumdisplay.php?f=89)
-   -   Lizard Skin Sound and Thermal insulation (https://vansairforce.net/community/showthread.php?t=83216)
Bdalporto 02-28-2012 09:18 AM
Watching TV last week end I saw this product.
http://www.lizardskin.com/
It looks like a pretty good product. Not toxic, weight? (about 17 lbs. for 30 square feet), easy to apply, can be painted. I have not heard of anyone using this stuff but I am considering it. But like anything else we use in an airplane it needs to be thought through carefully. So what do others think?
Brian
RV8RIVETER 03-02-2012 06:26 AM
I don't know of anyone who has used that product.
I have sprayed the firewall and interior of my plane with this.
http://silentcoating.com/sr_500.html
Not flying yet so cannot say there. You can definitely tell the difference in the way the skin or firewall vibrates when struck before and after. I had some overspray to remove and I can also say it is **** hard to remove. But it does add weight as any product would, about 6 - 7 lbs.
M McGraw 07-16-2014 06:27 PM
Update?
Just wondering.... Is the 6-7 lbs for the total cockpit area and do you find it was helpful now that you are flying?
Thank you
DanH 07-16-2014 07:21 PM
Apply what you want on sidewalls, but there are very few products suitable for the cabin side of a firewall. Both Lizard Skin and SR500 look like genuine Darwin Award materials to me.
flyboy1963 07-17-2014 08:52 AM
testing needed?
the MSDS makes these sound a lot like an acrylic paint, no doubt a spin-off of the spray-on boxliner industry.
Seems to be relatively 'safe', as in, not combustible when dry....but it's behavior at high temps IS in question.
RVbySDI 07-17-2014 09:55 AM
I don't think combustibility is the real concern when using these type of products inside the cockpit. The real danger is the 'off-gassing' that will occur when the product is heated. What will you be breathing during an emergency when the firewall starts getting hot?
jjhoneck 07-17-2014 11:07 AM
One honest question for the sound-proofers: Why go to such great lengths to attenuate noise, when a good pair of Lightspeed ANR headsets is proven to be more effective?
It just seems like the risks of corrosion and weight gain cannot be justified.
N15JB 07-17-2014 11:34 AM
Agreed. I went to some effort to sound proof my -10, from firewall to baggage bulkhead. It is noticeably quieter than uninsulated -10s, but still way too noisy to fly without a good ANR headset. In retrospect, it was not worth the time, effort or expense.
Jim Berry
RV-10
Johnnybgoode 07-17-2014 11:53 AM
This is perhaps the best small airplane perspective I've seen to date on this subject. Shave ounces by cutting lightening holes then add soundproofing pounds. Bite the ANR bullet - I remember my first experience with a set in the C-130 coming back from deployment. My third or fourth trip over, so I knew the effects of several days of 8-hour flying and was shocked how much better I felt after each day of flying this trip. Those were David Clark's - now using Bose in the Herk and modding DC's for the -4.
Enjoyed the post JJHoneck.
Patrick
