K1100 Nut Plate Question
On K1100 nut plates, in order to dimple all three holes there is a conflict because of the diameter of the dimple dies will flatten out the other dimpled holes. Curious if it is acceptable to over size the screw hole so the dimple from the piece being screwed in fits into that over sized hole? In the past I just dimpled away and hoped the screw would take care of the larger screw hole dimple.
You can grind off a bit of the shoulder on the female die, to give clearance for the previously made dimple.
Change rivets
Don't bother dimpling for the attach rivets - then the problem goes away...:)
Just use reduced head NAS 1097 rivets and countersink. |
I agree with Gil, use 1097 rivets. In the RV 10 Van called out for a lot of plate-nuts to be dimpled. This is a big waste of time when 1097 rivets work so well for this application.
First dimple the screw hole and then use a ground-down 3/32 die for the rivet holes. There are plenty of other areas you will want the modified die, so it won't go to waste.
Here ya go!
You can buy them 8-32 and up with dimples.
Read the tech info pages in this link http://www.gen-aircraft-hardware.com.../nutplates.pdf We go by MS numbers, you should be able to find what you are looking for by the pictures and charts. |
Small dia. 3/32 die
Cleveland tools sells a small dia 3/32 female die. Item Number : DIE4263S
for $18.00. Dimple the center hole first then use the small die on the sides. Works the same as grinding off one side of a standard die except you do not need to make sure that the flat side is lined up correctly. I use my small dia. die most of the time. I rarely use the standard size. Mostly because the small one is already on the squeezer. |
The Van's Class instruction
Do not dimple the platenut mounting holes - countersink them. The only function of the rivets is to hold the platenut in place when the mating screw has not been tightened and the rule of not countersinking metal less than 0.032" does not apply. You do have to be careful but that is the way to do it as taught to me by Van's elite instructors and I have since installed hundreds of them this way and it works perfectly. I use regular NAS426 3/32 dia rivets. This method allows the platenut to sit flush against the back of the part it is mounted on.
Bob Axsom |
Some good best practices here...thank you all. I've certainly done my share of tool mods so grinding down the sides is a "duhhh" for me, not sure why it hadn't hit me before. I like the idea of the smaller diameter ones as well from Cleveland. My only concern with countersinking the mounting holes if if you go just a tad bit too far the rivet head will not hold but in general not a bad idea.
why dimple or countersink them at all?
I am a new builder so I don't claim any knowledge, but what is the point of dimpling or countersinking any nut plate other than that is what it shows on the plan? I have a hard time seeing that a dimpled or countersink rivet would be any stronger than a regular rivet. In fact, I think you could make a good argument that because more metal is there with no countersink that it would be stronger left alone. All the rivet does is keep the bolt or screw from spinning. What the head of the rivet looks like does not matter.
Is it just one of the things required to meet the 51% rule like having to fabricate shims and other little pieces that could easily be included with the rest of the kit? |
You do not want rivets sticking up and interfering with the part you are going to be attaching with a screw. |
I see a little need for more exposure here
Bob Axsom |
Well when that happens
Bob Axsom |
Try countersinking a tad too far on scrap....
(For nut plates)... you can see that the rivet will "backfill" somewhat and often make an acceptable squeeze. If you countersink for nas1097 rivets and you went too deep, keep going for a normal 426ad3 rivet. I often got the required depth just using the hand deburring tool with the countersink bit. You sure dont need much for those tiny heads. You quickly learn the right looking depth.
nutplates
The nutplates you have are for the rod ends that are used as pivot bearings for the rudder. They are probably i/4" or 5/16" thread size. There is not an issue with clearance there. Later, you will be installing a lot of #6. and #8 size nut plates, which will be used to fasten a part flat on the part the nutplate is mounted to, like inspection covers, or the fairing at the tail. In this case, the surface on top of where the nutplate is mounted must be flat, thus the dimple/countersink for the rivet. |
If you happen to have a Knipex 8603-180 7 inch wrench, just use 426A (soft) rivets for most all of your edge nut plates.
got it!
Mike, now would be a good time to be in Cameron Park. We got 12" of snow so far last night and it is still coming down like crazy. My satellite dish is covered and we are not getting TV! ugg! |
Take a good look at the setup next to the multimeter box, bottom of the vert row, you can see the flush rivets and the countersunk nutplate, and the cover piece with the countersink all in relation to each other.
When a flat head screw is inserted here, the cover will be flat on the bulkhead frame, and the outer surface of the cover will be smooth. Not the greatest photo, but best I could find on short notice. Hope this makes it a bit clearer :confused: ![]() |
| All times are GMT -6. The time now is 09:07 AM. |
