VAF Forums
-   RV-12/RV-12iS (https://vansairforce.net/community/forumdisplay.php?f=73)
-   -   Skyview Avionics Received! (https://vansairforce.net/community/showthread.php?t=82782)
txaviator 08-28-2013 08:29 PM
Are the cylinder temp probes, and the fuel pressure sensor NOT included with the Skyview avionics? Since I'm going Jabiru, I called Dynon after receiving my avionics. They gladly agreed to swap out the Rotax probes for Jabiru probes. But the Dynon rep told me that within that same bag, that I should remove the fuel pressure sensor before sending the probes back. I haven't located the probes or the sensor he mentioned. I'm guessing they must be included with the Rotax?
Thanks.
DonFromTX 08-28-2013 09:37 PM
Yeah, no probes or sensors until you order the engine.
txaviator 08-28-2013 09:52 PM
Many thanks, Don.
MacPara 12-13-2014 05:04 PM
Originally Posted by MacPara (Post 654329)
I just finished page 42D-22 step 3. The WH-P600 and P601 (ORN/BLK) wires that were run to each headset block on the left and right side are the power supply for the headsets. They are fused with 5A on WH-00026 and are connected through WH-P440 (ORN/BLK) to pin 17 (AUDIO POWER) on the Options plug.
The instructions have you cover the ends with a heat shrink tube and cable-tie them to the headset plugs. As Van's doesn't know what type of headset you're using, it's up to you to find a suitable plug for it and install it in the seat pan.
The wiring is definitely there and everything is set up to install the power outlets.
I am replying to my own post to clarify something about the headset power wires WH-P600 and P601. The one thing that I didn't check back when I posted about them was *when* they would actually be powered. Now that I finished installing a parallel LEMO plug next to the standard plugs, I can tell you that the power comes on with the Main switch.
And it is a great feature to be able to run an active noise-canceling headset without having to rely on batteries.
