VAF Forums
-   -   Jack solution (https://vansairforce.net/community/showthread.php?t=82273)
Bill.Peyton 02-04-2012 02:04 PM
Jack solution
I am at the point where I need to make some jacks for the 10. I have seen a couple of examples using two Harbor F. 24" bottle jacks, adding a bottom plate and a top plate, then jacking from the fuse immediately under the spar. What are folks doing for a solution, I am soliciting any ideas?
rleffler 02-04-2012 03:48 PM
Here's what I did. It's a little more beefy, than just welding a plate to the bottom. I got a friend to fabricate a piece that screws into the tiedown hole and then slides over the top of the jack piston and a friend of his did the welding. This helps with stability when the jack is in the air.
I know if at least one person that looked into selling these, but the problem is that the freight will most likely be more than these cost to make. Any good welder should be able to fabricate with minimal direction.
Bill.Peyton 02-04-2012 04:21 PM
Bob,
I can assume the jacking it from the tie down locations is approved by Vans. I think I remember reading it somewhere, it just fails me at the moment. I was going to jack it from the center, although it might not be as stable. On my Piper there is a jack plate built into the structure that has a nub to center and hold the jack from slipping. Your jacks look great !
Bill
greghale 02-05-2012 11:10 AM
jack stands
I placed the jack stands under the wing spar attachpoint under the fuselage..
http://www.nwacaptain.com/jackstands.html
Greg...
TSwezey 02-05-2012 04:45 PM
Greg...
That's what I used to do also.
Bill.Peyton 02-05-2012 06:08 PM
I was thinking of using a similar method as you Greg, but supporting it under the spar the entire length. I would just glue a piece of rubber on top of the cross piece the entire length. That would avoid having to remove the lower gap cover.
Aerosport1 02-05-2012 06:12 PM
Bill I made the jacks for Bob and the ends that screw into the tie down threads. I made these for my airplane and they work great. I have used
Them for 2 years.
Geoff
douglassmt 03-21-2012 11:12 AM
Somebody oughta...
"Somebody" oughta make all the parts to the jacks using Bob/Geoff's design - except for the jacks that we can all buy at HF. That would cut way down on the shipping costs and there might be a market for such a package. Buy the package, drop in the jack from HF.
Phil 03-21-2012 11:21 AM
This is what I used...
http://www.amazon.com/Camco-57371-Ol.../dp/B000EDUUL2
I put these on a 2x12 base. Then put a 2x6 between them and the bottom of the spar. It works great.
The tail is tied down to a concrete anchor in the floor. My plane has been in the air for 3 months. I need to get motivated to get those wheel pants done. :mad::mad::mad:
rleffler 03-21-2012 02:00 PM
First off, I need to give Geoff credit. It's his design. I just supplied the jacks. Geoff and I have had several conversations on the subject. The opportunity is that shipping will probably run more than the product costs, which makes them harder to sell on the net. BTW, the jack isn't dropped in, it's welded to the stand. At least the ones that Geoff and I have are that way.
My recommendation would be to take a photo to your local welder along with the jack and have them fabricate them locally. It's not rocket science. I think it would be less expensive.
What may be beneificial for Geoff or somebody to produce the device to screw into wings to prevent the jacks from slipping. I don't know if Geoff is willing, but I really like the units he made for me. I don't have my photos at the office or I would have included it in this post.
bob
