VAF Forums
-   -   16gb 32gb or 64gb? (https://vansairforce.net/community/showthread.php?t=82160)
DiscoverThruCruisin' 02-01-2012 04:20 PM
16gb 32gb or 64gb?
How many gb do you normally use for your aviation apps? I'm branching out to an iPhone and wondering which gb to get. Thanks in advance.
Subwaybob 02-01-2012 04:32 PM
32
I have the 32 and can't seem to fill up 1/4 of it...:eek:
But as my Dad always says: "Bring a big gun to a knife fight everytime"
humptybump 02-01-2012 05:55 PM
Not less than 32bg.
If you get curious and download all of the charts for the USA then you need the 32gb. There is a period leading it to chart expiration when you have two sets of everything. When is happens, I often fall below the 50% mark. Which means 16gb would run out.
RFazio 02-01-2012 06:07 PM
I Agree With Humpty
I have the 32 Gig and am using about 1/3. But, like Humpty says you need some room for updates. Also as you get to know the phone your going to be putting other apps on there. I've got a 2 gig GPS that works with no wifi or 3g signal. The entire US is loaded on the phone. It works really well. I've got a few other apps, it is easy to start filling them up. How about music?
SHORTRV7 02-01-2012 06:38 PM
Mine is a 16G, almost full, 1025 pictures of which 5% are videos, get at least the 32g
roadrunner20 02-01-2012 06:46 PM
I have 16GB. 8.2GB available
1573 photos
269 songs
10 pilot chart sectionals
10 videos
Snowflake 02-01-2012 06:48 PM
My 32GB iPhone 4 has never been over about 75% full, and that's with pretty heavy loading with Apps, Music, and US Charts (which are only sort of useful up here north of the 49th).
DonFromTX 02-01-2012 08:22 PM
I sprang for the 64gb, talk about way over the top overkill. I will never get half of it used.
RV6_flyer 02-01-2012 09:34 PM
I have the 32 Gb. I had 3 Aviation Chart apps with the entire country and filled up the memory when all three tried to up everything without deleting the old version first. I will not do that again.
As others have said, if you are going to use ONE and only ONE Aviation chart App, you will be ok.
The 32 Gb is better. It can hold several different Aviation chart Apps and only if you miss manage it poorly, you will have all the space you need.
The 64 Gb is best. The 32 does everything I need but the 64 would allow for more growth.
I only got the 32 Gb because I will want a newer larger one when one of the newer versions get released. I did not know what it could do when I purchased it. Plan was to only use it for charts but to experiment with it as a laptop replacement. It is good for the aviation charts but great as a laptop replacement. Use in for more things that I thought I would when I purchased it.
DiscoverThruCruisin' 02-02-2012 07:21 AM
Thank you!
Thank you all for the responses. I appreciate your time. I believe I will try to spring for the 32mb, just might have to wait a little longer ;)
Rebecca
