EXP2Bus setup for external master relay
I'm troubleshooting a starting problem with my EXP2 Bus using an external master relay setup. For those using it, can you reply with your setup
I think this may be the proper setup. Can anyone verify this is correct? Or help with the setup. From EXP2 Bus ALT to Alternator output BAT to Battery+ BAT to Master Relay "B" terminal Square K1 pads jumped together with a #12 wire P10 to the center lug of the master relay J16 connected to J10 |
| All times are GMT -6. The time now is 06:47 PM. |
