VAF Forums
-   -   Knots or MPH?? That Is The Question (https://vansairforce.net/community/showthread.php?t=81947)
Geico266 01-29-2012 06:55 PM
Originally Posted by rv9aviator (Post 623326)
Switched my EFIS over to Knots today. One more nice thing about electronics. Not a big deal in the 9. I just went from 70MPH to 60 knots on final and from 60 MPH over the numbers to 50 knots.
See! You can gain 10 MPH by switching back to MPH!
pilotian 01-29-2012 07:44 PM
knots
simple: Knots
Ron Lee 01-29-2012 08:35 PM
I am ambidextrous and can use all three systems in various situations. For flight planning, I use 150 knots along with knotical miles which makes it easy to roughly guess trip/leg durations. On the rare occasion I have to file a flight plan...knots.
Airspeed indicator...MPH.
ao.frog 01-29-2012 09:15 PM
Easy: knots are for airplanes and boats, mph are for cars...
Just ask any aircraft company (Boeing, Airbus, General Dynamics, Lockheed, etc...)
Since all charts are in NM, it makes sense to use knots both for planning and flying.
rvmills 01-30-2012 01:32 AM
Originally Posted by Geico266 (Post 623334)
Aviators! ;)
Ships going into port still require pilots. They come out on small boats and board the ship, and take control of the docking of the ship with tugs and side thrusters....... and you guest it....... they use MPH inside the harbor. ( I have no idea if that last part is true, I am getting bored again. :D)
Yep...Harbor Pilots (and its a good gig, from all reports!)
and...Nope...not MPH (they'd be tossed out of the bridge, and overboard...in which case it wouldn't be such a good gig!) :eek:
Where's the popper?! ;)
Bob
islandmonkey 01-30-2012 01:57 AM
We should use Strawberries
We should use strawberries. After all it is just a number. Just make sure you use one number, stick with it, and have an easy way to convert to other measurements.
I use the numbers in the POH for the plane I am flying and ensure the ASI is referenced as to what it indicates. I do not mind doing the calculations between knots, statute miles or kph as I have flown all three many times.
I do prefer knots though as 1 nautical mile is one minute of arc on a great circle track.
I will use knots in my RV-4 as that is the standard here in Europe.
The use of knots has come out of maritime history and being British I am kinda proud of our history of circumnavigation, measurements of time and other discoveries.
NickAir 01-30-2012 04:03 AM
Older General Aviation/Military/Non Aviation Civilians
Started flying: General Aviation aircraft were with ASI's in MPH.
Military: Knots
Non Aviation Civilians: MPH
Best way that I have found is to fly using knots, now a days.
Exception: If aircraft is using an ASI carded with MPH. Many still are MPH.
Know the simple conversion: 1.15/0.87
prkaye 01-30-2012 07:05 AM
Soon as they start marking maps with knots to show distance from place to place, then it will make sense to use them.
A Knot equals one minute of latitude. That's a pretty fundamental link to what you see on your charts.
Ron Lee 01-30-2012 08:40 AM
Did you mean "nautical mile" instead of "knot?"
prkaye 01-30-2012 08:44 AM
Yes, clearly.
Another reason that I like nm (and, just to be clear about it, by extension, nm/hr or "knots") is that it is very close to exactly 2 km (similarly, 2 km/hr), which is the Canadian standard for speeds on the road. So when I talk to my non-aviation friends it makes the conversion to road speeds extremely easy to approximate in my head.
