iFlyRV10 Flush Locks -- success?
Has anyone successfully installed the iFlyRV10 flush locks? If so, I'd really like to see pictures.
For those of you who still have not done so, please do not install the lock where I did. The short story is there is too much slop in the rotational aspect of the lock. Therefore when any significant force is applied to try and force open the door, it just slips by and wha-lah, it's open. I've considered going lockless... but that's a different topic. If I do decide to install the flush lock, then I'll place it vertically over the flush handle system. That way the force used to try and force it open will be applied to the lock itself in a liner manner not in rotation. What do you guys think? BTW, here's a picture of what not to do. ![]() -Jim |
Jim,
I had those same locks installed close to where you've got them and they worked out great. Not exactly sure what the issue is from your description - give me a call and maybe I can help. Bob |
I have those locks installed in the same position and they have been fine for more than three years. You can overpower it, but it takes quite a bit of force. I am not aware of any slop in the mechanism.
I know you could overpower the lock if you were determined to break in to the airplane, but I am not sure that is such a bad thing. I would rather a determined thief overpowered the lock to get in rather than break out a window. It is hard to imagine a lock on the RV-10 door that a determined thief could not get around. I imagine this is true for most light airplanes whether certified or experimental. |
After further discussion with those who have done this before me, I think my primary issue is that I did not cut away the section of the flush *handle* piece so that the flush *lock* could be in its place. This caused the arm of the locking mechanism to be much longer and therefore the slop in the lock barrel is exaggerated.
Oh yeah, those two holes above the flush aren't supposed to be there either...that was me riding the threads of some epoxy and I went too far. Not worried about that part. Fill it and sand...it'll disappear. Thanks for the help. -Jim |
IFLYRV10 Flush locks
Reviving an old thread, but does anyone have photos of the locks and install process. Seems they don't sell them anymore and I am trying to roll my own with the help of a local locksmith.
Thanks, |
Just purchase these and save yourself a lot of time. I installed them on my completed 10
http://www.aerosportproducts.com/pro...e-door-handle/ |
We also have the Aerosport Products low profile handles, they're great, and easy.
+1 for Aerosport products on my RV10. They work great and look great and not as much friction and weight. The flush handles have mechanical interference just after 90 degrees so the 180 degree planearound latch is not compatible with them. It is compatible with the Aerosport Products handle.
Flush door locks
So if I were to say that I already had the flush latches and wanted to stay on that track and come up with a flush lock solution, would anyone that has installed them have photos?
Cheers, |
flush lock
I have a set of flush locks that I would sell. Bought and never used.
| All times are GMT -6. The time now is 07:35 AM. |
