Cessna Split Master Dimensions
Anyone have the "suggested" cutout dimensions for the Cessna split master (with bezel)? It looks like it is designed to be a pressure fit with the bezel installed, so there is some ambiguity as to the exact dims.
I'm seeing about 0.75"W x 1.4"H as the proper cutout. Does anyone have the "suggested" dims they can share? Thanks, Scott 7A Finshing |
Just installed mine (red split master switch from ACS). I don't have any suggested dimensions so it was file a bit/try, file a bit etc. The final cut-out for a nice snug fit is 1"13/32 x 11/16. Hope this helps.
Fin 9A Australia |
Hi Scott,
The cutout we use when having them laser'ed is: .78" x 1.4" Which still might take a wee bit of cleaning up, but it's worked pretty well for us after dozens and dozens of those. Cheers, Stein. RV6's - at war with 1 cowling! |
| All times are GMT -6. The time now is 07:08 PM. |
