VAF Forums
-   RV-7/7A (https://vansairforce.net/community/forumdisplay.php?f=7)
-   -   Stall warning (https://vansairforce.net/community/showthread.php?t=80717)
brick 01-01-2012 07:56 PM
Stall warning
Hi VAF I'm installing a stall warning vane in my 7A. When the vane itself was rolled and welded it is a little off center. I was able to buff a little off the vane to allow clearance from washer. My question is does the vane move quite freely with no resistance? at the moment there is resistance. ( I have used all the appropriate washers to this point) I could buff a little more off around the area where the bolt fastens it. Any input would be appreciated. Thanks in advance. Ken
Wayne Gillispie 01-02-2012 05:19 AM
It should take very little finger pressure to move it. If not keep working at it while it is easy to get to. My stall buzzer energizes 5 kts above stall, so no adjusting required. Also round the corners to keep from catching clothes- approximately 1/8" radius. Lubricate pivot with LPS-1 before closing up area.
brick 01-02-2012 05:56 AM
stall warning
Thanks Wayne I will keep working at it until there is next to no resistance!!:)
TSwezey 01-02-2012 07:27 AM
Very good advice!
brick 01-02-2012 09:04 AM
Originally Posted by TSwezey (Post 612205)
Very good advice!
Thanks for the back up Todd!!
gasman 01-02-2012 12:39 PM
Might be best to leave dry.
brick 01-02-2012 04:48 PM
Thanks for reply !! Followed Wayne's advice worked out well, held off on lubrication though as it can have a tendency to become sticky due to dusty conditions. Most probably if I choose to lube I would use a dry graphite lube.
Wayne Gillispie 01-02-2012 08:56 PM
LPS-1: Provides a dry, thin, greaseless lubricating film, resists oil, dust and dirt build-up, fast acting penetration, displaces moisture on electrical components and delicate mechanisms.
You may want to use it occassionally and especially after flying through rain. I keep all three types of LPS on hand. LPS-1 will also not damage your micro switch.
brick 01-02-2012 09:14 PM
Thanks for the knowledge on LPS-1 Wayne. I assumed it was an oil or gel base as I was not familiar with the product.
Buffing down the vane went well. Once the vain trigers the switch, the spring tendency on the switch is able to send the vane back to original position!! Thanks again for helping!
